Filter for Impulse Noise
Marc Sugrue
Joined Jan 19, 2018
222
Hi. How can I filter out these impulse noises until without disturbing the pulse communication signal?
Data lines often use common mode chokes to supress noise. Common mode chokes contain very litte leakage inductance which provides a small amount of differential filtering when used with a very small differential capacitor and the common mode inductance has very little effect on the actual data signal. You can evaluate common mode effectiveness by winding the data lines around a ferrite.
38,736
One possible way to minimize impulse noise is to use a slew-rate limiting filter.
It will not affect signals below the filter slew-rate, but will suppress those faster than that.
What is the frequency of your signal?
