Fedora 25
Natakel
Joined Oct 11, 2008
54
Trying to install Fedora on a Pk5-se board with multiple drives. It installed successfully, but when it says to reboot, it hangs. It actually hung overnight.
I have a Core 2 Quad processor on the board, with 4gbs of ram. I'd appreciate any insight you could provide.
Looking to create a NAS
joeyd999
Joined Jun 6, 2011
6,281
I haven't used Fedora in about 15 years, so I can't help you. But, you could try Googling "fedora 25 hang on shutdown" and "fedora 25 hang on restart".
The answer, I am sure, will be out there.
Natakel
Joined Oct 11, 2008
54
Thank you for the responses everyone. Been a bit busy with issues (wife is ill and it's been a rough few weeks).
I did find the time to work on getting it installed, and succeded. The drive I was installing it on apparantly had a previous install of Windows or Ubuntu on it, so I used a drive wiping tool and tried again. This time it worked . . . it did hang for about 20mins on the next screen after the language selection, but the rest went normally, and the reboot was successful.
I then installed the free Amahi Home Server on it to test it, and so far like it. I had a bit of an issue getting it to place shares on specific storage drives, but finally figured it out. Like someone said, it's easy once you know how. One gripe about their help forums is I could never find a straight answer on how to manually set up shares . . . everthing I found just looped back to a pay program called Greyhole. I actually found the answer on a Fedora site, and it was quite by accident. It was an answer to a totally different question about drives but showed the tiny knurdle of info I needed.
Not bad for a free server . . . there are apps you can buy, like Greyhole (well, technically the apps are free . . . what you pay for is supposed to be the "One click installer" which takes care of any install tweaking you'd otherwise do manually) but I haven't needed to do that for my install. I may yet go with something else, but so far in testing this is looking like it fits the bill. Price is certainly right.
If curious I installed it all on an Asus P5K SE board running a Core 2 Quad Q6600 processor and 4GB DDR2 ram. I have four drives of different age and sizes installed, for a total of 2.4TB of storage. These are all salvaged parts from other computers. So far it has successfully streamed 4 videos simultaneously while at the same time downloading a large file, all without any video lag or performance issues. Amahi was installed in conjunction with Fedora Server 25.
Thanks again for the responses all. I have no idea why wiping the drive helped, if that's what it was. Perhaps the computer gods just got tired of messing with me . . . :confused:
Natakel
Joined Oct 11, 2008
54
Update . . . after almost a year of flawless operation my Fedora based server is now booting in emergency mode. I did a hardware check, and it seems one of the hard drives has failed.
It was not the OS hard drive . . . but a file drive. All the file drives are separate entities. I tired unhooking the problem drive to no avail. I have tried a few root command diagnostics directed at the file system . . . I get info that sda1 is mounted, but cannot continue.
Still looking into fixes . . . not had a lot of time to look at it.
joeyd999
Joined Jun 6, 2011
6,281
It may be trying to automount, at boot, the drive you disconnected.
Remove (or just comment out) its entry from /etc/fstab.
Natakel
Joined Oct 11, 2008
54
Thank you. I'll give it a try.
I've been very happy with the server. I knew that particular drive was iffy when I installed it. but I wanted the 300gb space it offered. It was a salvaged drive I had no history on. I guess I got what I deserved, lol.
I was gifted a better PC recently . . . If I have to redo the server I'll use the gifted frame (just a motherboard, CPU, and RAM). It's an i5 750 on a Gigabyte GA-P55M-UD2 board. It boots into bios, but I haven't poked it with enough diagnostic sticks yet to pass it as serviceable.
Natakel
Joined Oct 11, 2008
54
Just an update. Tried some trouble shooting but could never get it to recover. I went ahead and finally just started over, but kept running into errors when installing Fedora Server on it, and then the Amahi app. I think the motherboard could be having issues. I've set that board aside and will diagnose it later (it's pretty long in the tooth anyway).
Used the Gigabyte board and the i5, and I went with another NAS system based on Debian Linux. It doesn't have as many features as Amahi did, but it was much easier to set up, actually plug and play pretty much. Working like a champ.
Sprung for a new case for it - A DIYPC MA08 SECC MicroATX mini tower. Newegg had a good deal on it. Went together good. Takes up very little space.
Brownout General Electronics Chat 4
Brownout Software & IDEs 24
