Not to mention Lucky Luke, who did it a long long time agoGot a flash for the krauts & the tabloid - tunnel diodes were doing just that 40 years ago. Also, Cerenkov radiation derrives from photons exceeding light speed in the medium they are passing through. It's a common phenomenon.
Do you have an example of something with mass that is faster than light?There are a lot of things faster than the speed of light....
Like beenthere says, EM waves in the particle model are photon based and therefore possess no mass. So I'm still open to suggestions about something with mass that is faster than lightwell phase velocities of waves exceed speed of light in vacuum.
You will find the speed is finite - its the quantity that is unlimited!!I don't know if it has mass, but the speed of bullshit is unlimited!
Lol! In this case, it doesn't necessarily have to be from a bull does it!Yes, let's remember that the propulsion is usually from a fan blade.
Using quantum entanglement, information induced into a particle with mass can be transferred to its pair particle with mass instantaneously to induce a mirror image change in it. That involves mass and FTL but it doesn't involve mass actually going FTL. A Bose-Einstein Condensate is a grouping of atoms that exhibit the properties of a single quantum particle and can be influenced to perform quantum leaps that are faster than light but the distance and/or time is an inverse function of the energy violation. The greater the violation, the shorter the distance and/or time it may violate the conservation of energy. This usually involves very small distances and time scales though.Do you have an example of something with mass that is faster than light?
Dave
As long as they don't exceed light speed on vacuum. The normal light speed on water is substatially lower than the one in vacuum. That causes refraction, since photons entering/leaving the material change velocity and attack angle. Thus we have Cerenkov radiation visible in water submerged reactors.Got a flash for the krauts & the tabloid - tunnel diodes were doing just that 40 years ago. Also, Cerenkov radiation derrives from photons exceeding light speed in the medium they are passing through. It's a common phenomenon.
So no mass travelling faster than light. That is the crux here.Using quantum entanglement, information induced into a particle with mass can be transferred to its pair particle with mass instantaneously to induce a mirror image change in it. That involves mass and FTL but it doesn't involve mass actually going FTL.
