Fast switching mechanism
Atif hussain shah
Joined Sep 6, 2020
18
Screenshot_20210711-103200.pngI want to use a very fast Spdt Rf switch Masw20000 and want to control it through Fpga.it has two control signal inputs A and B. The control signals required for this switch are 0V and -5V for switching of one state and -5v and 0v for switching to other state.
The problem is that i cannot provide -5v from fpga.
One solution is to use an inverter but its responce is slow.
I want to genarate control signals 0v and -5v within 1ns.
If Any idea or solution
38,762
Here's the LTspice simulation of a common-base PNP level shifter which may meet your needs.
Note that the transistor must be a device designed for fast saturated switching (no 2N3906 or similar general purpose transistors) and the input must be a high speed, fast rise-time driver circuit capable of driving an 80Ω load at 0-5V or a 42Ω load at 0-3V.
Atif hussain shah
Joined Sep 6, 2020
18
Thanks for reply
Most BJTs like above you have used(2N5771) has on and off time around 10 to 15 ns. I think this time will effect the switching speed
Papabravo
Joined Feb 24, 2006
22,111
Thanks for reply
You are falling victim to misleading datasheet parameters. Look at the currents involved for the datasheet value. Then look at the currents in the simulation. It is a world of difference.
