Fast AC voltage regulation
maurouhle
Joined Dec 30, 2016
24
This is about Siemens X-ray’s control equipment released in the 60’s. I have a question about the “fast AC voltage regulation” used to power 2D21 / 5727 gas thyratron tubes, neon tubes and some other electronic components.
The voltage controller unit was always shown on diagrams as a black box. 220V unregulated in, 220V regulated out. One could see the unit, called Isostat, built only with transformers, Inductances and capacitors. There were jumpers for 50/60 Hz operation.
I figure the voltage compensation was done by phase shifting, but if not too off the subject here and if possible, I would like to see a basic diagram and understand the basics of it.
There was also a test device for measuring the grounding between the units that generated a constant 10A AC current which applied between 2 ground points, should not show a resistance higher than 0.2 ohm. If I remember all well. Thanks
