Fan wiring question
sghioto
Joined Dec 31, 2017
8,751
That's what I thought.
Try tapping the PWM wire to ground rather then rubbing it sideways. It's also possible that the frequency of the waveform from the module is important.
Tonyr1084
Joined Sep 24, 2015
9,744
By all accounts, if striking the white wire to ground and scratching it on ground makes the fan run then momentarily striking the white wire to ground via PWM should also make the fan run. Based on your first video.
Tonyr1084
Joined Sep 24, 2015
9,744
Pin 3 is providing a square wave. HIGH then LOW then HIGH then LOW (repeat). When low it should be providing pathway for the signal to reach ground. If you want to forego the diode then connect the white wire to pin 7 of the 555. It does not provide any "HIGH's", only "LOW" and "Open" (or floating). Which is the same thing you're doing with striking the white wire to ground.
ElectricSpidey
Joined Dec 2, 2017
3,358
The diode is shown correctly but better to use pin7 to drive the PWM.
Might be kind of hard to tap pin 7 from that module. (probably in use anyway)
How do you know the OP connected the diode correctly...did the OP show you something that wasn't posted?
It is also possible the diode in series with the NPN of the 555 is not taking the PWM pin low enough.
Also, without seeing a diagram of the circuit I can't confirm that the grounds are common.
ElectricSpidey
Joined Dec 2, 2017
3,358
There seems to be a bit of confusion here...I was asking to be sure the diode was connected to the module correctly...not the custom build.
The OP said nothing about trying the custom build.
Also, the OP was talked into buying a module that doesn't have pin 7 available, then constantly told that pin 7 would be better.
In my opinion the OP should have been shown a PWM module that has an NMOS output transistor, but I said nothing because I don't really like conflicting with other people's advice unless it is blatantly wrong in my opinion.
sghioto
Joined Dec 31, 2017
8,751
Because you posted after Tony's reply without referencing whom you were speaking to I thought you were referring to Tony's schematic. Which BTW I posted back in #14 using pin7 as the output before the module was suggested.
ElectricSpidey
Joined Dec 2, 2017
3,358
Ok, you're right I should have quoted the reference...a bad habit of mine.
But you could have given me the benefit of the doubt of whom I was speaking to, because it is quite obvious that your circuit doesn't need the diode and the OP had just stated that the module didn't work.
But ok, let's just chalk this up to miscommunication on my part, and get back to trying to help the OP.
Tonyr1084
Joined Sep 24, 2015
9,744
Apparently it needs to pull the PWM line to ground to work but not at a 100% duty cycle.
Here's my version of a 555 circuit with an appx 90% fixed duty cycle using pin7 to drive the PWM input.
Apparently yes, you did. Sorry I overlooked that part. Pin 7 would be the way to go IF the TS was building from scratch. As for a module? One would have to know for a certain what they want and what the module can do. As far as I could tell, those modules were designed to power a fan that would run at full speed when powered with 12V on red and ground on black. The TS has a fan that requires a signal to run. Likely the blue wire is for a tach or feedback to a controlling circuit. Unfortunately the TS isn't up on electronics terms and lacks a common understanding of the same. Not putting anyone down - just saying that we could be given some clearer information. When asked "What's 2 + 2?" the TS response didn't really address the problem in the way we were asking.
rescuejg
Joined Mar 25, 2023
23
You are correct, I did not do a custom build. I have only experimented with the module from Amazon.
rescuejg
Joined Mar 25, 2023
23
@sghioto @Tonyr1084
The reasons I believe it is a ground.
1. In the OEM configuration it is captured by a screw to the metal part the fan is attached to.
2. I am presuming this fan is custom made for Chrysler and there would be no reason for an extra wire if they had no intent on using it. It is rare for a car mfg to use an off the shelf part. The very specific connector that was on it indicates it is made specifically for Chrysler.
3. The blue wire doesn't go through the loom to the connector, where they could have put it in the connector female side and no connect / no pin on the male side.
rescuejg
Joined Mar 25, 2023
23
You are correct, about me not being "up on electronics terms and lacks a common understanding of the same" and my apologies to this group for that. I sincerely appreciate the patience, comments and desire to find a solution for a person you don't know. That is what forums are all about. I am a member of other forums, where I am fortunate to have done the same for others with lesser knowledge about a subject matter.
