Fan wiring question
ElectricSpidey
Joined Dec 2, 2017
3,357
When you say a low side switch you mean using a PWM that will turn the negative on/off?
Correct.
And fortunately, low side PWM modules are quite common, in fact you would be hard pressed to find a high side one. (They are available but as rare as the dodo)
There also some with variable frequency as well as duty cycle...something you might want to consider.
BobTPH
Joined Jun 5, 2013
11,620
The fact that putting 12V on the wire had no effect, but grounding it does, means that the input is likely pulled up internally. That is why I asked you to measure the voltage on it. That voltage would tell you what a safe PWM voltage would be.
But simply using a low side switch to ground to ground it would always be safe. So go ahead and try the circuit posted by @sghioto.
rescuejg
Joined Mar 25, 2023
23
So hook up:
Black to ground
Red to +12v
Then measure white wire voltage using volt meter leads from White to Ground?
sghioto
Joined Dec 31, 2017
8,744
I found this module on Amazon I think will work if you don't want to assemble my circuit.
Just need to add a diode in series with the PWM white wire.
NE555 Duty Cycle Frequency Adjustable Square Wave Signal Generator Board Module by Envistia Mall
sghioto
Joined Dec 31, 2017
8,744
Looks like the same. Yes would still need a diode.
The diode is there to block the DC voltage output from the module when the output is high which is appx 11 volts.
Thus the PWM only sees a low signal
1N4001 diode should be safe enough.
rescuejg
Joined Mar 25, 2023
23
12 volt is OK because of the added diode.
Remember this is experimental but I believe the module will work.
Is it strange that the fan doesn't work with 12v applied to the PWM wire? Or is it simply one of those things where the fan wants to see the modulated signal.
Should I try 5v to see if that will run it on high speed?
rescuejg
Joined Mar 25, 2023
23
@sghioto @BobTPH
I hooked Red and Black to + - respectively and then applied 5v to the PWM wire and the fan does nothing. Does that change anything in your analysis? Do we still think the square wave generator might be the answer?
rescuejg
Joined Mar 25, 2023
23
@sghioto @BobTPH
I tried the module from Amazon with no success. I put the diode in between the module and the PWM wire.
With DVM the output wire from the module was around 3.8v Should I have seen it going from 0v to 3.8v rapidly? When I saw no reaction of the fan I adjusted the two screws on the module.
I also tried again with the PWM wire to ground (module removed from the equation). Scratching the PWM wire on a ground causes the fan to operate. It's really weird. HERE is another video.
Any other suggestions?
Anyone have some spare time? I can send you the fan to see if it is something simple to figure out?
sghioto
Joined Dec 31, 2017
8,744
Try adjusting the duty cycle of the module to read 2.5 volts on the DVM, then connect directly to PWM wire and see.
2.5 volts would indicate a duty cycle of 50%. The lower the DVM reads indicates a higher duty cycle on the low side which is what I think the fan needs.
Looking at the video the fan seems erractic at startup.
