Failure to circuit simple Op-Amp
levydee
Joined Oct 18, 2016
14
Good evening,
I am having issues getting a simple op-amp circuit to run. I am using a LM339 quad op-amp IC with out success. The simple circuit is pictured.
I am using a 9v Battery to power the circuit. I have pin 12 to ground, pin 3 to Vcc, pin 4 to ground and pin 5 high. Should this not output a high signal to pin 2 and power my LED?
Please help!
WBahn
Joined Mar 31, 2012
33,222
First off, the LM339 is not an op-amp, it is a comparator.
Second, it has open collector outputs.
Third, it is only spec'ed as being able to sink 6 mA (though typical is 16 mA).
Do yourself a favor and go look up the data sheet and study it.
Also, the best way to communicate information about a circuit is via a schematic.
levydee
Joined Oct 18, 2016
14
Its a comparator that uses 4 open loop configured op-amps.
The open collector output comment is all I needed. Thank you.
Dodgydave
Joined Jun 22, 2012
11,395
Notice the Output has an "Open Collector" so it will not give a positive output, you have to to "pull it up" with the load...
levydee
Joined Oct 18, 2016
14
Does the 16ma current output sink mean that my collector load can only run 16ma to ground through the open collector output without damaging the IC?
dl324
Joined Mar 30, 2015
18,474
16 mA is the typical current; the guaranteed minimum is 6mA
Whether this will damage the chip depends.
levydee
Joined Oct 18, 2016
14
Thank you for all of the good information so far. As suggested earlier, I have drawn up the simple schematic. I am still not having any luck at all to get this damned LED to light up. Any suggestions?IMAG0657.jpg
WBahn
Joined Mar 31, 2012
33,222
Not surprising. To get it to light up the output has to be LO. Fine. But that means that the non-inverting input (pin 5) has to be lower than the inverting input (pin 4). Since the inverting input is tied to the negative rail, that means that the non-inverting input must be lower than the negative rail. But in your circuit, the non-inverting input must always be somewhere between the negative rail and the positive rail.
Try using another voltage divider to provide the signal to the inverting input that is somewhere around midway between the two rails -- this is easily accomplished by just using two equal-value resistors.
levydee
Joined Oct 18, 2016
14
Thank you for all of your input so far. I have got it working, but I am confused and would like to understand why the output must be LO. The output is an open collector to an NPN transistor. 1) Is Vbe grounded to pin 12? and 2) how does a LO output activate the base of the NPN?
Thank you
WBahn
Joined Mar 31, 2012
33,222
Thank you
The output is an NPN transistor (or an NFET for CMOS versions) and it can only pull the output pin LO. To make this happen, the internal signal driving the base/gate of the transistor is taken HI; but this is an internal signal that you don't have access to. The output that you see is the collector/drain of the output transistor.
Tonyr1084
Joined Sep 24, 2015
9,744
An Op-Amp that provides both power and ground has an output that is tied internally to the supply rails (positive and negative). An "Open Collector" output is not tied to positive. It can only be "OPEN" or "GROUND" (or whatever the negative rail is).
Not sure what you're trying to accomplish so I may be wrong here, but your inputs to the op amp are (if both resistors are the same value) 4.5 volts on the non-inverting input (the positive) and zero volts on the inverting (negative) input. When positive is more positive than negative then the output will be OPEN. Since it does not provide power it can't be HIGH. Only if pin 4 were tied to the positive rail would the LED come on the way you have the circuit drawn. The reason why is because the negative input (9V) would be more positive than the positive input (4.5V) When negative is greater than positive the output will pull to ground, and your LED would light.
The circuits that have been provided shows a fixed voltage on the negative input. R1 and R2 show a fixed resistor and a photo resistor. Therefore the voltage on the positive changes when the photo resistor value changes with light level. You have a comparator that looks to see which input is higher. When positive is more positive than negative then the output goes open, thus turning the LED off.
