Extreme Low Frequency Project
fsoender
Joined Dec 10, 2015
26
I'm looking into to start a low frequency transmitter project. I'm not an expert in electronic circuits, but I do get most :)
I need help with how a transceiver with H-bridge and coil work or show examples. There is not much on the net to find.
Transmitting distance would be approx. 4-5 meters.
I want it to send "1" at 12Hz and "0" at 9 Hz.
I will use FSK with a ATmega microprocessor.
Can anyone help me out with ideas or samples?
GopherT
Joined Nov 23, 2012
8,009
Ha! What size antenna do you plan to use?
If something like this was practical, it would be done on a regular basis. Since it is not, why don't you explain your end goal - something like: how could I transmit a logical 1 and logical 0 over a distance of 4 to 5 meters.
Also, you could tell us something about why 9 and 12 Hz are important to your design.
Note: sending a frequency 5x higher is very difficult. Even when an antenna is twisted through your house at 50 or 60Hz with huge currents as your stove turns on or off results in only a fairly modest signal - try to build an battery powered amplifier for the 60 Hz emitted by the mains power in your house.
fsoender
Joined Dec 10, 2015
26
I just picked the frequencies, can be anything low. It have to be low frequency since I want to penetrate 30mm steel.
Ive seen it been done, coils are not that big, approx. 40cm long and 5cm dia.
GopherT
Joined Nov 23, 2012
8,009
I think you should tell us where you saw somebody transmit 10 Hz through 30 mm of steel with coils smaller than a fist.
If it were possible, many issues with a submarine' inherent Faraday cage could be overcome and many advantages of a submarine's inherent Faraday cage could be defeated. There is a guy at the Navy Research lab named Joe, he will want to talk to the OP if he can do this.
21,228
Am efficient half-wave dipole antenna at 12 Hz would be about 7,767 miles in length. That would not be possible in the continental US, but maybe you could interest Mr. Putin in the project. OOPS -- it is only 6,600 miles from Europe to the Asian Pacific, so I guess that won't work either. What do you suppose will be the IR losses in such an antenna? Hmm...10 AWG is about 1 Ohm per 1000 feet, so that's only 41 KΩ. As you can probably surmise there are technical challenges that just may be out of reach.
fsoender
Joined Dec 10, 2015
26
There is many applications where this is used, but it's not a fist size. I said approx 40cm long and 5cm dia.
21,228
I'm curious about why you would want to use an H-bridge to drive your coil. I don't think I've ever seen an RF design do that.
GopherT
Joined Nov 23, 2012
8,009
Ok, I believe a coil that size will work. But, it would have to be more of a solenoid instead of a transmitter. A 16" x 2" solenoid should be able to ring a plate of 1 1/4" steel like a bell.
