I dont think you read the link.
Obviously you only read "using an opamp as a comparator" and not the rest.
Were here to help. This idea or application of yous has been being done for decades. You are insulting the people trying to help you by not taking the advice or SIMPLY blowing off the info given.
Useing a comparator with a internal reference voltage, you will get a 0 or a 1 at 5v. TTL which means TRANSISTOR TRANSISTOR LOGIC. Designed to do EXACTLY what you want to do. and about your quote:With a pull-up resistor and a 0 to +5V power supply, the output takes on the voltages 0 or +5 and can interface with TTL logic:
You HAVE to take the information we give you and READ it.If my input from the load cell is 0V when no load is applied and 20-50mV when a load is applied, comparing it to something like 5mV would STILL only give me 20-50mV output at most
