experimental problem in boost converter
mimou
Joined Oct 23, 2023
Hello everyone, I have designed a boost converter. The input is from a solar panel providing 8W/6V, with the desired output voltage set to 12V and a load of 20 ohms. I calculated all parameters using literature equations, taking into account the parasitic elements (Fs=20kHz, D=53%), and simulated it using Matlab. However, I encountered a problem in the experimental results; for instance, the output voltage measures only 8V.
I don't know where the problem is, can you help me please.
28,576
As a switching boost circuit the current from the magnetic storage element is in series with the internal resistance of the photo array. so no, it will not deliver as desired. (the real world is cruel that way)
pwrtrnx
Joined Feb 1, 2024
21
you need to assign values - e.g. C3 = 1000uF, L1 = 1mH, C2 = 220uF, RC1 = 22 ohms
pwn freq = 50kHz, Don = 20% say
for starters.
pwrtrnx
Joined Feb 1, 2024
21
easy starting points, ESR of components not critical at this stage - but do provide some damping, typ figures would be 0.1 ohm for the L and 0.2 ohm for the Caps, Rds-on for the fet should be 0.05 ohm
pwrtrnx
Joined Feb 1, 2024
21
The posters main problem appears to be that the energy source is not stiff enough to run the sim properly - a battery with a resistor is a very good sim for a fully irradiated solar panel. Vbatt = V open ckt, R = Vopen ckt / I short ckt
Ian0
Joined Aug 7, 2020
13,315
That's what I thought.
An even better simulation is a current source with a load of diodes in series across it.
mimou
Joined Oct 23, 2023
Thank you so much for your responses,
for ESRs I use the values from the datasheets (rl=0.1ohms, rc=0.08ohms, and ron=0.05ohms). The simulation has been done, but the issue lies in the experimental results.
Irving
Joined Jan 30, 2016
5,195
The main issue I see is that, as was said above, the performance of the boost converter is highly dependent on the impedance of the source, which will depend on the level of illumination. Here is an LTSpice simulation plotting output voltage against source series resistance:
28,576
At least some of those switcher supplies use a fast diode to supply the low impedance for when the inductor is delivering current. The diode is just upstream of the inductor,and is forward biased as that end of the inductor becomes negative relative to ythe other end.
