i am currently working on a similar project and have the same problem with a exhaust valve. Could you solve the problem? And had the exhaust valve 4-Pins or 3-Pins?
After a while I discard the project in how it was going. I did finish the project but in a different way. Made my own project and coding to create a unique controller that can be used for not only the F56 jcw pro exhaust, but also for the BMW m2 stock exhaust and M2 performance. Ow and also for the clubman f54 jcw and JCW pro exhaust.
But because it’s now a wide selling product I can’t tell you how I made it.. but for sure you have to need a scope to see the pwm signals IC to do the coding. The motor is a 4 pin, but only used 2 pins.
