.exe to matlab
bertus
Joined Apr 5, 2008
22,995
An .exe file is most times a compiled for a specific processor.
You will need to know for what processor the file is made.
If you know that you can "decompile" it using a dissasembler to assembly language.
bertus
Joined Apr 5, 2008
22,995
It will be VERY difficult to revive the source code from an .exe file.
It all depends on the type of processor and if there are other files used by this .exe file.
The best you will gat is a large assembly listing.
kubeek
Joined Sep 20, 2005
5,796
If you like stepping through tens of thousands of lines of assembler, then disassemble it.
Otherwise you are more likely to find the author and make him send you the source files than to disassemble it to anythig useful.
22,116
Then he will need a program to convert the original source to Matlab. Listen very carefully -- you are the only person on the planet who has the time, patience, and motivation to do the job manually for this one-off project. Further you are the only person on the plant who has the capability to write the piece of software you are requesting. Time is a-wasting so you better get started.
35,093
Hee, hee.:rolleyes: OP has deaf ears. My answer was "no" back at post #3.
22,116
Did "NO" -- even "Hell No!" ever stop the HHO or free energy crowd. Every field of human endeavor has its myth chasers. Here is yet another "tinaja"
http://www.tinaja.com/
Note particularly the exciting field of Magic Sinewaves.
