Excess voltage on a mechanical switch?
MaxHeadRoom
Joined Jul 18, 2013
30,813
The difference of 6v is probably not going to make a difference, also being under 60v it is not considered a safety hazard.
Particularly that the circuit current is lower.
28,332
Contact ratings for voltage and current usually relate to the claimed switch life number of on/off operations. The voltage rating is related to contact arcing while the switch is opening and when it is in the open position. The current rating is about the contact heating as current is flowing through the switch.
Considering the normal safety margin switch makers apply, it is not likely that there will be any problems using that switch.
