Excel file read and manipulate - Matlab
Judas543
Joined Jan 26, 2010
60
Before I post something about this:
does anyone know how to read an excel file with matlab and manipulate it?
I know how to open it and put it in different categories:
[num txt raw] = xlsread('c:\matches.xls')
NEED HELP ON THESE THOUGH:
Count the number of entries that have one blank field
Copy these entries in a new array that you display in order to review and verify the errors
Finally you decide to remove these defective entries from your array (for which one field was left blank) by
copying only the valid entries to a new array, which is going to be your working database
http://www.sendspace.com/file/q1dp3j - excel file .xls
retched
Joined Dec 5, 2009
5,207
Does the file have to be saved as an Excel file?
Can you save it as a comma delimited format, then import the data?
johndoe45
Joined Jan 30, 2010
364
you can choose save as text file like retched said from excel
than comma delimit it.
open text with matlab
in matlab
load filename.txt
that is it. then just put filename(row numbers,column numbers)
for example i want all data in column 1
matlab syntax
filename:),1)
