what if my audio has 10k output impedance run to 3 meters unbalance to 10k input impedance. what will happen to my audio? rule of thumb is ratio 10:1
I think the "golden ears" might allege that they can hear the difference, but I remain a skeptic on this point. You don't say if the audio is analog or digital, and you provide no other details on the equipment or the cabling, so it is hard to give an accurate answer. What "rule of thumb" are you talking about?
I guess I missed that one when I worked for Wadia.You know, the audiophile rule of thumb that input impendence should be 10x the output impedance.
That's understandable - back when Digital was the cool thing in audio.I guess I missed that one when I worked for Wadia.
how about frequency?Well, it seems like you are making a 2:1 voltage divider so, your signal voltage will be cut in half.
yeah now thats why im confuse LolI think the "golden ears" might allege that they can hear the difference
my soundcard has 10k input impedance and my guitar has a dc resistance of 10k
speches peaking around 3khz-5khz, sibillance "S" 5-8khz, my wire capacitance is 350pf, just attenuation? or are they gonna ruined or missing some frequency in between? i only care about 40hz-16khz (+/-3db)With 10kΩ impedance you would need about 1nF capacitance in the cable to start attenuating high frequencies above 16kHz.
Heck, I can't even hear above 3kHz!
One thing I know with a high degree of confidence is that the DC resistance of the guitar pickup has absolutely no relevance to this problem.my soundcard has 10k input impedance and my guitar has a dc resistance of 10k
I tried it. My Les Paul can deliver 1V peak all day, 3V peak if you hammer it.The signal from a guitar pickup might be too low for a soundcard input.
Have you tried it?
Guitar cord measured at 18 pf per foot would need 55 feet to start affecting high frequenciesyou would need about 1nF capacitance in the cable to start attenuating high frequencies
Such is the value of an empirical thinker and experimenter.I tried it. My Les Paul can deliver 1V peak all day, 3V peak if you hammer it.
Do I assume that 1V output is a result of active amplification?I tried it. My Les Paul can deliver 1V peak all day, 3V peak if you hammer it.
I worked with a band for years. I designed a few novel amplifiers. It was inevitable that I accumulated some information.Such is the value of an empirical thinker and experimenter.
No. That's a Les Paul guitar plugged into an oscilloscope. 1 meg in an x1 probe. I needed to find the highest output voltage of an electric guitar in order to calculate clipping limits for an input amplifier stage.Do I assume that 1V output is a result of active amplification?
That's wicked!No. That's a Les Paul guitar plugged into an oscilloscope. 1 meg in an x1 probe. I needed to find the highest output voltage of an electric guitar in order to calculate clipping limits for an input amplifier stage.
Look at my post again. I added on to it while you weren't looking.I don't see how a steel string vibrating no more than the width of a horse's hair can generate 1V.
Most guitar players piddle around at about 0.1 volt peak, but you need headroom for the moment they hammer a power chord.
