Ethernet Hardware Working ?
usmansa1
Joined Jan 22, 2017
40
My question is particularly confined to the scope when the bits are collected (RX) from the wire (CAT) to the point it is further considered as the valid frame (Preamble and Ethernet frame length).
1. Ethernet cable plugged in
2. Bits are started to move towards the Reciever
3. On reciever side what are the steps for these bits untill they are considerd as valid ethernet frame in terms of digital logic design for example either the data recieved from wire fed to some register then
checked from the register that whether the data fed is valid preamble or not to know the start of the frame ?
