etching pcbs with marker
kubeek
Joined Sep 20, 2005
5,796
Any colour, asl long as it is permanent. But some have trouble staying on the pcb or doing fine lines with enough coverage. A lot of trial and error, or repairing of tracks.
Unless the board is bigger than 100x100 I would go with chinese fab like jlcpcb. I even redid a layout of one board just to split it into two parts by function and ordered two sets that would fit in 100x100 - filled the rest of space with square vias to serve as a protoboard.
jbeng
Joined Sep 10, 2006
84
I've only used markers with black ink, but as long as the ink isn't water soluble, it shouldn't matter what color you use. It had been my experience that the common Sharpie marker worked well, but at some point they re-formulated the ink they use and it is now somewhat water soluble. I now use the variety called "Sharpie Industrial" which has ink which is not water soluble. The ones in the extra fine point are getting rather hard to find, however.
Here's an example of a board I recently made, using one of the pens in my plotter...
pager48
Joined Nov 25, 2018
161
boards are already on their way from jlcpcb but it will take a while for them to arrive.
I have both vero and copper clad boards and I just dont do well on vero boards. the last attempt to do it via vero board went to the trash. Transfering this amount of toner should be easier especially because the tracks are thick.
jpanhalt
Joined Jan 18, 2008
11,087
Years ago, a group was investigating using modified inkjet printers for printing the resist. Yellow worked better than black. The logic is that black is often a pigment (very small particles), the other colors are dyes, which when thoroughly dry are more impervious. Also,the ink jetters heated after printing and the dyes tended to fix better to the PCB than black.
Of course, black is easier to see, so that may offset any advantage of being more impervious that colors have.
dl324
Joined Mar 30, 2015
18,465
Unless the formulation has been changed, Sharpie Industrial Super Permanent doesn't work.
Sharpie fine point and ultra fine point permanent markers work. I've only tried black.
