Shut up or I'll kick your cat.Sounds like you're in for a treat of lots of fun, fun, fun...
It's turning out to be that kind of day.
Ha ha ha... here, have a read:Shut up or I'll kick your cat.
It's turning out to be that kind of day.![]()
AFAIK the 'oil life remaining' indication is based upon a revolution count? Hence the malfunction owes, perhaps, to a noise issue? -- In the absence of wider malfunction, or, at very least, the 'setting of an ECM code' It seems likely the difficulty is local to the specific indicator -- unless said count is via a 'dedicated sensor'?It says 82% of my oil life is remaining after 2.7 miles to the gas station and back, and I have 40.3 miles left in the 22 gallon gas tank, 1.35 miles after a fill-up.
Careful @#12! Such public expression of initiative, personal responsibility and all the 'orrible disobedience entailed thereby is certain to result in your 'flagging' as a revolutionary radical!The, "count" comes from a microprocessor that displays several sentences (one at a time) describing the status of the car and it's many, many, useless features.
I am not going to replace a bunch of over-engineered and mostly useless microprocessors. If this thing can't figure out the oil change times, I will just note the mileage, as I always have, and change the oil when I want to. If it can't figure out the gas tank is full, I will just look at the gas gauge. I also don't check the tire pressure every day just because the dashboard says they are low every time I start the engine. This gigantic pile of unnecessary and often wrong microprocessors is a study in bad design. That doesn't mean I'm going to throw thousands of dollars at it, trying to buy more badly designed microprocessors dedicated to functions nobody needs.
So, diagnose your little heart out. I'm not going to fix it.
You're right. I'm not a good little consumer. I'm probably already on a terrorist watch list and couldn't fly on an airplane if The President wanted me to fix his refrigerator.Careful @#12! Such public expression of initiative, personal responsibility and all the 'orrible disobedience entailed thereby is certain to result in your 'flagging' as a revolutionary radical!![]()
Motors, sheet metal and transmissions used to be the things that sent cars to the junk pile. Now, I'm guessing it is electrical issues. What a pain in the ass. My wife's van runs like a champ, 110k miles, no rust, perfect transmission. The power windows only go down, the electric mirrors don't work, the radio is intermittent, power rear doors are intermittent, and electric seat is rusted in place (that's my son's fault with a spilled coke about 10 years ago). In any case, I would love to see an electric to crank window conversion kit.You're right. I'm not a good little consumer. I'm probably already on a terrorist watch list and couldn't fly on an airplane if The President wanted me to fix his refrigerator.![]()
If you lived closer to #12 he'd probably buy the car from you. Less problems than his has.Motors, sheet metal and transmissions used to be the things that sent cars to the junk pile. Now, I'm guessing it is electrical issues. What a pain in the ass. My wife's van runs like a champ, 110k miles, no rust, perfect transmission. The power windows only go down, the electric mirrors don't work, the radio is intermittent, power rear doors are intermittent, and electric seat is rusted in place (that's my son's fault with a spilled coke about 10 years ago). In any case, I would love to see an electric to crank window conversion kit.
GM's not the only one that uses it. Called "mineral filled plastic". Not the correct 'fill' for that type of part, should be a glass filled material.My beef with GM is adding talc to their plastic fan blades (in the heater/AC) so they disintegrate at about 12 years old.
What are the purported advantages of said formulation? I cannot imagine talc, soapstone, etc. contributing anything in the way of structural integrity? - Is it, perchance, claimed to improve the product's thermal characteristics?Called "mineral filled plastic"
I'm under the impression that it's to make the plastics more environmentally friendly... and to help the industry sell more cars, and at a faster rate...What are the purported advantages of said formulation? I cannot imagine talc, soapstone, etc. contributing anything in the way of structural integrity? - Is it, perchance, claimed to improve the product's thermal characteristics?
Best regards
HP
Wonderful! Biodegradable motorcarsI'm under the impression that it's to make the plastics more environmentally friendly...
Best regards
HP
Aye! -- For some inexplicable reason - a brace of 'corporately conjoined' manufacturers of ultra-low cost Amateur Radio products (who 'hang their respective hats' in Starkville, Ms.) come to mindMy belief was that, in the long run, the absolute worst thing for the company's profits would be dissatisfied customers. Sadly, top company executives rarely have a long term view; they are chasing those annual performance incentive$.
I was quite confident that molybdenum disulfide is the most skookum lube base you can get, so I wouldn't list it as a way to cheapen up products, in fact I thought it was more expensive than other competing formulations....Name the physical property you want to tune and I can show you something that costs 0.35/lb that will change it.
Molybdenum sulfide is used for self-lubricanting polymers for bushings and glide surfaces.
Talc comes in many forms, the talc used in plastic is the fibrous form not the highly refined and finely powdered type known as "talcum powder". https://en.wikipedia.org/wiki/TalcWhat are the purported advantages of said formulation? I cannot imagine talc, soapstone, etc. contributing anything in the way of structural integrity? - Is it, perchance, claimed to improve the product's thermal characteristics?
Best regards
HP
| Thread starter | Similar threads | Forum | Replies | Date |
| F | Roles which skills translate well into IC Design / Layout | Jobs & Career Advising | 7 |
| Similar threads |
