ESR values
Guilngan
Joined Jan 26, 2008
9
I have just brought an ESR meter and would like to know do anyone have a table or chart where shows the esr values for capacitors from 0.01uF to 10,000uF....Note-there is no table/chart came with the meter...Thanks
beenthere
Joined Apr 20, 2004
15,819
A capacitor's effective series resistance depends quite a lot on the composition of the capacitor. The manufacturer usually publishes specs that include expected ESR for their capacitors.
jpanhalt
Joined Jan 18, 2008
11,087
If you just want a feel for the range of values, the easiest way might be to go to a distributor that has links to datasheets (I use DigiKey), pick out a particular size, voltage, and chemistry, and click on a few. John
The Electrician
Joined Oct 9, 2007
2,986
Be aware that the ESR of capacitors varies with frequency. The low cost ESR meters typically measure the ESR at a single equivalent frequency. I say equivalent frequency because some of them use pulse techniques.
To give the meter a bit of a test, pick some capacitor and measure its ESR. Then put a fixed resistor with a value of the same order as the measured ESR in series with the cap, and measure the series combination with the meter. The indicated ESR should go up by the amount of the resistor you put in series.
