no, the reading of the cap should not go past the zero point..the meter is zeroed with test leads shorted.Isn’t that what it should do?
Are you complaining about the 0 reading with nothing connected?
It all depends on what capacitors and what resolution of your meter.the reading of the cap should not go past the zero point..
Residual charge in the cap ?no, the reading of the cap should not go past the zero point..the meter is zeroed with test leads shorted.
BS. The amount of gain is controlled by the external components.hi this is the circuit. i didn't have a lm324 so i used a tl084. i the 84 has too much gain?
In structure, these are different op-amps.hi this is the circuit. i didn't have a lm324 so i used a tl084. i the 84 has too much gain?
thanks guys. i'am going to increase the value of r13/r14 to 1.5k.In structure, these are different op-amps.
LM324 -industry-standardoperational amplifiers.TL084-FET-Input Operational Amplifiers.
LM324.
GBW-1.2MHz.
SR-0.5.
TL084.
GBW-3MHz.
SR-20.
The original circuit used TL084.
https://www.qsl.net/iz7ath/web/02_brew/15_lab/06_esr/index.htm
There is some good information here. Test your circuit to make sure it is working correctly.
https://www.vintage-radio.net/forum/showthread.php?t=56933
