ESP8266-01 Interrupts
sairfan1
Joined May 24, 2012
63
I'm trying to setup interrupt in arduino based environment using board ESP8266-01, based on help i found on different sites i wrote following code, but when i program my device it continuously shows interrupt message "Interrupt Ocurred: 1" on serial monitor, while same program running if i pull down the pin it shows "Interrupt Ocurred: 0" that means I'm using correct port and it state changes when i do it on hardware, I pulled up pin externally as well, I also tried same program on NodeMCU for different input pins
Arduino:
#include <ESP8266WiFi.h>
const int InterruptPIN = 2;
volatile byte isrInterrupt_A = 0;
void ICACHE_RAM_ATTR IsrInterruptFunction();
void TestInterrupt();
void setup()
   Serial.begin(115200);
   pinMode(InterruptPIN, INPUT_PULLUP);
   attachInterrupt(digitalPinToInterrupt(InterruptPIN), IsrInterruptFunction, FALLING);
   Serial.print("Ready");
void loop()
    if (isrInterrupt_A = 1) {
      TestInterrupt();
      delay(1000);
void IsrInterruptFunction() {
  isrInterrupt_A = 1;
void TestInterrupt(){
  Serial.println("Interrupt Ocurred: ");
  Serial.println(digitalRead(InterruptPIN));
  isrInterrupt_A = 0;
