ESP32 RESTARTING PROBLEMS
minte_7
Joined May 19, 2023
11
Hello everyone,
We see that there are problems with our microcontroller, an ESP323-S3, power supply. The module starts correctly from 4.2V to 3.3V. However, when the voltage drops from this value, the microcontroller gives a "brownout" error which indicates that the supply current is not sufficient.
The input voltage goes first through a BOOST (https://www.mouser.es/datasheet/2/277/MP3120-2945726.pdf) to 5V and then through a LDO (https://www.mouser.es/datasheet/2/389/ld1117-1849389.pdf) to 3.3V as you can see in the attached image.
We believe that this problem could be due to the start of some bluetooth process of the microcontroller which requires a higher current peak than normal. Although in principle this should not create any problem since both the BOOST and the LDO are capable of supplying values above 300 mA.
