ESP32 File System Mount Failed (GFX Library)
John A Bonilla
Joined Mar 11, 2017
92
Hi Everyone,
I have been trying to use the ESP32 in conjunction with the 1.28" Round display and have had a hard time working with the SPIFFs system. I have tried uploading the data using the "ESP32 Sketch Data Upload" tool and seems to upload without issue. I have attached a zip folder with all of the program files. I know that my files are only 1.8 Kb so there should be no issue in terms of storage. The main code also gets uploaded fine, however the problem lies once the controller is done uploading. I receive the following error:
E (101) psram: PSRAM ID read error: 0xffffffff
ERROR: File System Mount Failed!
I have no idea how to correct this. I followed the video:
Code:
 * Animated GIF Image Viewer
 * This is a simple Animated GIF image viewer exsample
 * Image Source: https://www.pexels.com/video/earth-rotating-video-856356/
 * cropped: x: 598 y: 178 width: 720 height: 720 resized: 240x240
 * optimized with ezgif.com
 * Setup steps:
 * 1. Change your LCD parameters in Arduino_GFX setting
 * 2. Upload Animated GIF file
 *   FFat (ESP32):
 *     upload FFat (FatFS) data with ESP32 Sketch Data Upload:
 *     ESP32: https://github.com/lorol/arduino-esp32fs-plugin
 *   LittleFS (ESP32 / ESP8266 / Pico):
 *     upload LittleFS data with ESP8266 LittleFS Data Upload:
 *     ESP8266: https://github.com/earlephilhower/arduino-esp8266littlefs-plugin
 *     Pico: https://github.com/earlephilhower/arduino-pico-littlefs-plugin.git
 *   SPIFFS (ESP32):
 *     upload SPIFFS data with ESP32 Sketch Data Upload:
 *   SD:
 *     Most Arduino system built-in support SD file system.
 *     Wio Terminal require extra dependant Libraries:
 *     - Seeed_Arduino_FS: https://github.com/Seeed-Studio/Seeed_Arduino_FS.git
 *     - Seeed_Arduino_SFUD: https://github.com/Seeed-Studio/Seeed_Arduino_SFUD.git
/* Wio Terminal */
#if defined(ARDUINO_ARCH_SAMD) && defined(SEEED_GROVE_UI_WIRELESS)
#define GIF_FILENAME "/Blinking.gif"
#elif defined(ARDUINO_RASPBERRY_PI_PICO)
#elif defined(ESP32)
#else
#endif
 * Start of Arduino_GFX setting
 * Arduino_GFX try to find the settings depends on selected board in Arduino IDE
 * Or you can define the display dev kit not in the board list
 * Defalult pin list for non display dev kit:
 * Arduino Nano, Micro and more: TFT_CS:  9, TFT_DC:  8, TFT_RST:  7, TFT_BL:  6
 * ESP32 various dev board     : TFT_CS:  5, TFT_DC: 27, TFT_RST: 33, TFT_BL: 22
 * ESP32-C3 various dev board  : TFT_CS:  7, TFT_DC:  2, TFT_RST:  1, TFT_BL:  3
 * ESP32-S2 various dev board  : TFT_CS: 34, TFT_DC: 26, TFT_RST: 33, TFT_BL: 21
 * ESP8266 various dev board   : TFT_CS: 15, TFT_DC:  4, TFT_RST:  2, TFT_BL:  5
 * Raspberry Pi Pico dev board : TFT_CS: 17, TFT_DC: 27, TFT_RST: 26, TFT_BL: 28
 * RTL872x various dev board   : TFT_CS: 18, TFT_DC: 17, TFT_RST:  2, TFT_BL: 23
 * Seeeduino XIAO dev board    : TFT_CS:  3, TFT_DC:  2, TFT_RST:  1, TFT_BL:  0
 * Teensy 4.1 dev board        : TFT_CS: 39, TFT_DC: 41, TFT_RST: 40, TFT_BL: 22
#include <Arduino_GFX_Library.h>
/* More dev device declaration: https://github.com/moononournation/Arduino_GFX/wiki/Dev-Device-Declaration */
#if defined(DISPLAY_DEV_KIT)
Arduino_GFX *gfx = create_default_Arduino_GFX();
#else /* !defined(DISPLAY_DEV_KIT) */
/* More data bus class: https://github.com/moononournation/Arduino_GFX/wiki/Data-Bus-Class */
Arduino_DataBus *bus = new Arduino_ESP32SPI(27 /* DC */, 5 /* CS */, 18 /* SCK */, 23 /* MOSI */, -1 /* MISO */, VSPI /* spi_num */);
/* More display class: https://github.com/moononournation/Arduino_GFX/wiki/Display-Class */
Arduino_GFX *gfx = new Arduino_GC9A01(bus, 7 /* RST */, 0 /* rotation */, true /* IPS */);
#endif /* !defined(DISPLAY_DEV_KIT) */
 * End of Arduino_GFX setting
/* Wio Terminal */
#include <Seeed_FS.h>
#include <SD/Seeed_SD.h>
#include <LittleFS.h>
#include <SD.h>
#include <FFat.h>
// #include <LittleFS.h>
#include <SPIFFS.h>
#include <SD.h>
#elif defined(ESP8266)
#include <SD.h>
#else
#include <SD.h>
#endif
#include "GifClass.h"
static GifClass gifClass;
void setup()
  Serial.begin(115200);
  // Init Display
  gfx->begin();
  gfx->fillScreen(BLACK);
#ifdef TFT_BL
  pinMode(TFT_BL, OUTPUT);
  digitalWrite(TFT_BL, HIGH);
#endif
/* Wio Terminal */
  if (!SD.begin(SDCARD_SS_PIN, SDCARD_SPI, 4000000UL))
  if (!LittleFS.begin())
  // if (!SD.begin(SS))
  if (!FFat.begin())
  // if (!LittleFS.begin())
  // if (!SPIFFS.begin())
#else
  if (!SD.begin())
#endif
    Serial.println(F("ERROR: File System Mount Failed!"));
    gfx->println(F("ERROR: File System Mount Failed!"));
  else
/* Wio Terminal */
    File gifFile = SD.open(GIF_FILENAME, "r");
    File gifFile = LittleFS.open(GIF_FILENAME, "r");
    // File gifFile = SD.open(GIF_FILENAME, "r");
    File gifFile = FFat.open(GIF_FILENAME, "r");
    // File gifFile = LittleFS.open(GIF_FILENAME, "r");
    // File gifFile = SPIFFS.open(GIF_FILENAME, "r");
#else
    File gifFile = SD.open(GIF_FILENAME, FILE_READ);
#endif
    if (!gifFile || gifFile.isDirectory())
      Serial.println(F("ERROR: open gifFile Failed!"));
      gfx->println(F("ERROR: open gifFile Failed!"));
    else
      // read GIF file header
      gd_GIF *gif = gifClass.gd_open_gif(&gifFile);
      if (!gif)
        Serial.println(F("gd_open_gif() failed!"));
      else
        uint8_t *buf = (uint8_t *)malloc(gif->width * gif->height);
        if (!buf)
          Serial.println(F("buf malloc failed!"));
        else
          int16_t x = (gfx->width() - gif->width) / 2;
          int16_t y = (gfx->height() - gif->height) / 2;
          Serial.println(F("GIF video start"));
          uint32_t t_fstart, t_delay = 0, t_real_delay, delay_until;
          int32_t res;
          uint32_t duration = 0, remain = 0;
          while (1)
            t_fstart = millis();
            t_delay = gif->gce.delay * 10;
            res = gifClass.gd_get_frame(gif, buf);
            if (res < 0)
              Serial.println(F("ERROR: gd_get_frame() failed!"));
              break;
            else if (res == 0)
              Serial.print(F("rewind, duration: "));
              Serial.print(duration);
              Serial.print(F(", remain: "));
              Serial.print(remain);
              Serial.print(F(" ("));
              Serial.print(100.0 * remain / duration);
              Serial.println(F("%)"));
              duration = 0;
              remain = 0;
              gifClass.gd_rewind(gif);
              continue;
            gfx->drawIndexedBitmap(x, y, buf, gif->palette->colors, gif->width, gif->height);
            t_real_delay = t_delay - (millis() - t_fstart);
            duration += t_delay;
            remain += t_real_delay;
            delay_until = millis() + t_real_delay;
            do
              delay(1);
            } while (millis() < delay_until);
          Serial.println(F("GIF video end"));
          Serial.print(F("duration: "));
          gifClass.gd_close_gif(gif);
          free(buf);
void loop()
visionofast
Joined Oct 17, 2018
106
I guess for settling SPIFFs in your code,you should set proper configuration in arduino IDE for flash memory at first,as memory size, clk freq,etc. and if you dont know the parameters,there must be a SPIFFs indentification example code in esp32 default library.
BTW that most of the codes I experienced with SPIFFs and ESPxx boards had been so faulty ,maybe beacuse the CPU unit is not well designed for side memory pipeline processes.
LAOADAM
Joined Nov 21, 2018
956
Hi Everyone,
Code:
* Setup steps:
*   FFat (ESP32):
*   SPIFFS (ESP32):
*   SD:
/* Wio Terminal */
#else
#endif
/* Wio Terminal */
#include <SD.h>
#include <FFat.h>
#include <SPIFFS.h>
#include <SD.h>
#include <SD.h>
#else
#include <SD.h>
#endif
void setup()
  // Init Display
  gfx->begin();
#ifdef TFT_BL
#endif
/* Wio Terminal */
  if (!FFat.begin())
#else
  if (!SD.begin())
#endif
  else
/* Wio Terminal */
#else
#endif
    else
      if (!gif)
      else
        if (!buf)
        else
          int32_t res;
          while (1)
            if (res < 0)
              break;
            else if (res == 0)
              duration = 0;
              remain = 0;
              continue;
            do
              delay(1);
          free(buf);
void loop()
Hi.
I did test of it, and got rebooting loop error:
rst:0x8 (TG1WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
did you ever meet this error?
