Hello people...
I'm learning about ESP32-cam and I'm new to electronics, so I need some help. I want to do a project in which esp32-cam takes a picture and sends it to me, when he "sees" movement. For this, I use a pir. It has a schematic of how to do it, with an esp32-cam, a pir, and an ftdi. But together, you have to put a transistor, and I want to know if the assembly I made is the same as the diagram, in photo number 2. So I want to know if the diagram in photo 2, is done right as in diagram 1.
Thank you.
Thank you.
