There are at least five false of fact statements in the above quote.The drawing was kinda tricky to reduce but, once reduced, yielded a Wheatstone bridge which, in its simplest configuration, comprises four equally valued resistances for the legs of the bridge and another equally valued load across the junctions of the two legs.
Do you have a problem with that?
It's not very tricky to redraw (not reduce) into a bridge topology.
It's not a Wheatstone bridge as it lacks a galvanometer or other measurement device.
Such a bridge rairly has equal value resistors, instead it depends on equal ratios.
The center measuring device is chosen to have a high impeadance relative to the legs.
That is a list of my problems with your ex cathedral pronouncements. WBahn nailed a correct method of analysis way back at the 4th post. Stop trying to make sense out of the senseless.
