Equaliser Question: Cannot Identify SymbolWithout more information about what the device is (audio, video, radar, ?) and the rest of the circuit it is impossible to say exactly what is going on, but it probably is acting as a high-pass or peaking circuit. Photo?
ak
Hi guys,
Sorry unfortunately because I do not own the schematic I cannot post it. I can tell you that its meant to be an Equalizer. I understood the LC series circuit but shouldn't there be a value on the L? is 101 the value of the L?
Thanks in advance.
So how can I approach it? I have the values for the capacitors as it can be seen in the picture and I know the Frequency that enters the SW3 for all 10 positions.No, it is a non-standard device. Something like that is a custom-wound inductor with several "taps" (access points).
I guess I am having trouble understanding what you plan to do. Is this a repair? If no, noth8ng happens to inductors - they are rarely (never?) the source of a problem unless a wire breaks from a tap.So how can I approach it? I have the values for the capacitors as it can be seen in the picture and I know the Frequency that enters the SW3 for all 10 positions.
Depending on what you plan to do with the circuit, and you did your calculation to find your desired values, pop in some inductors and put a scope on to see how all the filters are working.I am trying to build one from the schematic and I am trying to gather the components.
I have calculated the inductance and I will order an Inductor for each of the tap.
