Eprom programmer help please Total Novice.
30,789
Looks pretty decent, but I don't specifically see the 27C512 on there?
I have used one of the ebay specials, Topwin or TOP similar to ebay 251299446383
SteveHow
Joined Jul 2, 2012
80
Thanks for the reply. When you say you don't see the 27C512 are you talking about seeing them in the list of supported devices. ?
If you scroll down to the very bottom of the web page, I infact do see the 27C512 listed. (EPROM Section)
Also, is it safe to assume that the 27C512 is the same as the M27C512-10F1.?
Finally, the data sheet for this EPROM states it needs 12.75 Vpp to enable programing mode. Can this EPROM programmer supply this voltage.
Finally, finally :) Would the ERPOM programmer need any of the adaptors.
As I said, the is a completely new area for me. It's complex and could take years to get a grip on this subject, this is why I am asking you guys. Surely, these questions are no brainers to some.
Thanks
Steve
bertus
Joined Apr 5, 2008
22,995
The 27C512 is given here, a bit lower on the given page:
27C64 , 27C128 , 27C256 , 27C512 , 27C010 , 27C020 , 27C040 , 27C1001
M27C1001 , M27C2001 , M27C4001 , 27C080 (A19) , M27C801 , M87C257
2716 (Vpp25V) , 2732 , (adapter DIP24) , 2764 , 27128 , 27256 , 27512 , 27010,
Vpp12.5V (21Vpp Modify Circuit)
It looks it should work.
