Enabling 555 timer after 10 second push button
Status
Not open for further replies.
danadak
Joined Mar 10, 2018
4,057
Its a bad practice, depending on how power is removed from a circuit,
to tie large caps onto CMOS input pins. Reason, when power supply collapses
the Cap has to discharge thru parasitic diodes in CMOS input and you can create
localized hotspots on the die which are destructive. Simple fix is between
Cap and CMOS input put a small R to limit power down current. Size
for datasheet spec (if there is one, sometimes referred to as injection current),
or if no spec available limit to a few mA.
Regards, Dana.
eetech00
Joined Jun 8, 2013
4,753
Regards, Dana.
To what circuit are you referring?
eT
Status
