EMP?
Status
Not open for further replies.
MisterBill2
Joined Jan 23, 2018
28,197
I've been researching on this topic on Quora, etc and some users have said, even an EMP of high voltage will not cause damage unless it is from a nuclear or atomic blast. Another user said, if the implant is in brain it might cause damage and that is why bullet fragments and shrapnel in brain is left there instead of removing, or if it is pace maker or defibrillator, it might cause damage.
Mod: Deleted link to a prohibited device.
The EMP gun only seemed to disable things, I'm hoping the implant I have might be disabled and not cause any shock or other damage with such an EMP gun.
To disable a brain implant you need to get an MRI scan done. Those devices use a very strong magnetic field but they are safe when used as intended. So get the head scan at a licensed MRI establishment and it should be safe.
I didn't say I had a brain implant, I wrote what users on Quora said, MRI is magnetic resonance imaging, it will be injurious if I went into that with an implant. Better would be X-RAY or CT scan, no magnetic or electrical waves there..
MisterBill2
Joined Jan 23, 2018
28,197
The purpose is indeed to disable or destroy any implant. At least I thought that was your intent.
12,265
At this stage, it is not imagined. It is a reasonable possibility.
No, it isn't. For reasons given in the thread referenced above and many others on this and other fora, it is not reasonable, nor "reasonable", in any way. It is biologically impossible to operate on someone in such a way that they are completely unaware of it, or unaware that *something* unapproved / not-agreed-to has happened. Anesthesia, sedation, accupuncture, hypnosis - they all leave fingerprints, have aftereffects, and create memories of the event.
Separate from that is efficacy. Can an implant "do stuff"? - Absolutely. For some Parkinson's patients, Deep Brain Stimulation is a godsend miracle cure. (I have near-first-hand experience with this.) But can an implant plant an idea or a "memory", cause a thought, transmit what you are seeing or thinking - ? No. Period, zero, amen - no.
[/QUOTE] You should be locked up in a psychiatric institution and given shock therapy round the clock.[/QUOTE]
Why? If you have experience with ECT, you know it will not change MB2's mind to agree with your dilusions. If you don't, you are recommending torture. Now who needs psychiatric help? He sometimes is a bit arrogant, but you are violent. I reported your post to the moderators.
Status
