- Joined Jan 23, 2018
- 28,212
To disable a brain implant you need to get an MRI scan done. Those devices use a very strong magnetic field but they are safe when used as intended. So get the head scan at a licensed MRI establishment and it should be safe.I've been researching on this topic on Quora, etc and some users have said, even an EMP of high voltage will not cause damage unless it is from a nuclear or atomic blast. Another user said, if the implant is in brain it might cause damage and that is why bullet fragments and shrapnel in brain is left there instead of removing, or if it is pace maker or defibrillator, it might cause damage.
Mod: Deleted link to a prohibited device.
The EMP gun only seemed to disable things, I'm hoping the implant I have might be disabled and not cause any shock or other damage with such an EMP gun.
