Emergency stop button wiring
RosaGuerra
Joined May 23, 2017
8
What is the simplest way to wire an emergency stop button so it stops the power to an MCB rated at 160A powering a building?
vu2nan
Joined Sep 11, 2014
357
You would need to replace the 160A MCB with a 160A MCCB having 'under-voltage release' feature.
The e-stop push button switch NC contact, wired in series with the 'under-voltage release' coil, would make it failsafe.
- Nandu.
