is 5.8 instantaneous or max ? how can i solve a)
Thread Starter ahmed elbarky Joined Nov 13, 2016 9 Dec 25, 2016 #1 is 5.8 instantaneous or max ? how can i solve a)
dl324 Joined Mar 30, 2015 18,502 Dec 25, 2016 #2 In addition to this being in Homework Help where you need to show your best efforts; there's too little information.
Thread Starter ahmed elbarky Joined Nov 13, 2016 9 Dec 25, 2016 #3 dont know why the attachment isnt uploaded
crutschow Joined Mar 14, 2008 38,932 Dec 25, 2016 #4 ahmed elbarky said: is 5.8 instantaneous or max ? how can i solve a) Click to expand... Neither. All the currents are likely RMS. I'll give you a hint for a). Inductors don't absorb (assuming that "absorb" means dissipate) power. Do you understand AC circuits and phasor algebra? You will need that to answer all the questions.
JoeJester Joined Apr 26, 2005 4,390 Dec 25, 2016 #5 I see a flawed question. Look at the three given currents. Do they make sense? What is the source of the question? Check these two references: AAC's ebook external website On edit: The problem with the given currents could be a distractor which is why it was "never corrected." Last edited: Dec 25, 2016
JoeJester Joined Apr 26, 2005 4,390 Dec 26, 2016 #7 You need to show what you have done to solve these problems. Otherwise, I will assume the Emergency on your part isn't an emergency on my part. You can work through the problems by understanding those two links I posted.
