We can't eve start to help you understand how to determine resistor values when you haven't yet shown what circuit topology you are contemplating using. You need to provide a schematic that is your best attempt to come up with a circuit that you think will work. Don't worry about which opamp you are using or component values -- just the basic circuit topology to start with.Hi, I have a further doubt, what values should I choose for the resistors, obviously the ratio I choose will help me to have the amplification I want. Furthermore, I had thought of making two stages so as to obtain an output voltage, and a possible alternative that seemed valid to me was to use a buffer at the first stage and then another LM358 amplifier at the second stage, in which I sized the resistors so as to obtain the gain I buy between 0 and 5 Vvi seems like a valid alternative
Hi,Even the 741 has sufficient, barely, GBWP for these specs.
GBWP and Slew Rate are different things. An opamp might be adequate in one and not in the other. I was only talking about the GBWP. The TS needs to determine what their needed GBWP is and what their needed slew rate is and then consult the data sheets of the opamps they are considering.Hi,
Doesn't the 741 op amp have similar specs to the LM358 op amp?
The LM358 has GBW of 1MHz and slew rate of just 0.5v/us, which is not fast enough for 40kHz as specified. Max would be around 15kHz.
Thank you for FINALLY showing a schematic.
Hi,GBWP and Slew Rate are different things. An opamp might be adequate in one and not in the other. I was only talking about the GBWP. The TS needs to determine what their needed GBWP is and what their needed slew rate is and then consult the data sheets of the opamps they are considering.
Hi,Hi, I have a further doubt, what values should I choose for the resistors, obviously the ratio I choose will help me to have the amplification I want. Furthermore, I had thought of making two stages so as to obtain an output voltage, and a possible alternative that seemed valid to me was to use a buffer at the first stage and then another LM358 amplifier at the second stage, in which I sized the resistors so as to obtain the gain I buy between 0 and 5 Vvi seems like a valid alternative
