MaxHeadRoom
- Joined Jul 18, 2013
- 30,768
The only real way is a accurate picture of the physical unit itself.
Max.
Max.
Ok..... I understood! Should I show this symbol to someone else who knows this symbols? If yes I will keep it in mind, if no I will keep it in mind tooThe only real way is a accurate picture of the physical unit itself.
Max.
You mean that one from all this switches (let's take one of them) is the same switch that is connected in all the 4 places where is that symbol? If yes then ok XDhttp://www.digikey.com/products/en/switches/pushbutton-switches/199?k=&pkeyword=&FV=2080005,3ac0005,ffe000c7&mnonly=0&newproducts=0&ColumnSort=1000011&page=1&stock=1&quantity=0&ptm=0&fid=0&pageSize=50
You will wire it as normally on for Receive and push to talk (Transmit).
Yes, the top one works well for your application. It is four switches activated by one button. Each switch has three pins (twelve total) with six pins on each row. The first three pins make a switch (middle pin is the common and the one closest to the touch point is R. As you push, the center pin is connected to the far pin (of a group of three). That far pin in each group of three is the T.You mean that one from all this switches (let's take one of them) is the same switch that is connected in all the 4 places where is that symbol? If yes then ok XD
Ooooooo thank you very much bro thank you! Now I understand all this theme XDYes, the top one works well for your application. It is four switches activated by one button. Each switch has three pins (twelve total) with six pins on each row. The first three pins make a switch (middle pin is the common and the one closest to the touch point is R. As you push, the center pin is connected to the far pin (of a group of three). That far pin in each group of three is the T.
They're similar. The first one indicates a shielded/coaxial connection.Does it is same with something that looks like this?
????? Shielded coaxial connection??They're similar. The first one indicates a shielded/coaxial connection.
Like BNC, TNC, SMA, etc.????? Shielded coaxial connection??
The typical convention is if wires cross without a connection dot, there is no connection. That avoids the need for the "humps" in the marked up picture. When a wire intersects, but does not cross (e.g. a "T"), the connection dot is optional. Without the dot, a connection is still assumed.What is the difference between the following connections?
See this link! Maybe you will understand what I mean. Why this man made the typical connection or how its called like "T"? The components around this connection is not connected by the "T"? And the connection near the GND? The pin of audio IN where is connected? To the ground or to the pin of a PNP transistor?The typical convention is if wires cross without a connection dot, there is no connection. That avoids the need for the "humps" in the marked up picture. When a wire intersects, but does not cross (e.g. a "T"), the connection dot is optional. Without the dot, a connection is still assumed.
Well drawn schematics will be consistent in the way they use or don't use dots. You should never see a schematic like the marked up one...
It's a poorly drawn schematic.See this link
