Hey nice work dude!!! i'm happy to have a scientist here! keep it up. i think you considered my suggestions in the earlier post. let me build one and show it to my doctor friends. if they like you can open a company to produce them.ahh yesnow it's ok?
its not that whether it is used or not. and the circuit is similar not same. this doesnt fall under the prior art. so it is not liable to be revoked. check the patent details on the www.patentsonline.com. if you feel that this is wrong file a petition for it. patent infringement is very dangerous. milions of dollars of fine. so be very careful.Why would a simple amplified microphone and filter circuit have a patent?
This simple circuit might have been copied by the named inventors.
Car mechanics use a similar circuit.
They should be electrolytic ones. Their polarity must be correct.I have one more question about parts? its not a problem that capacitors: C1,C2,C6,C8 and C11 are electrolytic ones?
Your school project? I think this project is difficult for a studentdont worry , its only my school project![]()
Maybe an electronic stethoscope is good for a doctor who has a hearing deficiency. Then he can turn up the volume. The output can also be recorded.Hi
This is my project too and when I searched about that, I found here
I cant understand spanish, so I cant read that article at page 1. I need some information about advantage of electrical stethoscope to usual tethoscopes. Do you think it has any usage in medicine and if it has, why is the usual tethoscopes yet used? I want know the reasons of designing this circuit.
http://www.allheart.com/electronic-stethoscopes.html?gclid=CImysf7OnaECFQENDQodAja3zAIt seemed like a pretty intelligent idea, but I don't know if it ever went into production.
you are right, its good point but I mean if this unit can be replaced with the old stethoscopes? I dont think so. Its actually for special uses but I think with some good ideas it can be useful more, for example for someone who have a sick person at home and need to check her or his heartbeat several times a day. we can improve the circuit with microcontroller.Maybe an electronic stethoscope is good for a doctor who has a hearing deficiency. Then he can turn up the volume. The output can also be recorded.
The simple circuit in any language is a mic preamp, a lowpass filter and a power amp. It is probably too simple for a school project.
thanks for your informationAs I said earlier, I worked on an electronic stethoscope and I'm listed on the patent.
That was back when I worked for a product development company. Typically we worked for other companies--"An R&D department for hire"--but in this case the client was an individual inventor. However, he'd founded a company in the past, and he had the promise of venture capital funding.
Here's what I remember about the reason for an electronic stethoscope. His idea was that first, the volume in a conventional unit isn't very high. Second, listening down a tube obviously gives you a distorted version of the sound (even if doctors are used to it and say it's just what they need!) and lastly, if the signal were electronic, you'd have the ability to process it to emphasize particular kinds of sounds that you were interested in--there are apparently characteristic noises made by valves that don't open or close properly, to name one abnormality that I can remember, but there were others.
And one final reason for the project--he had the idea that there could be special units made for a teaching or consulting environment, so one doctor could apply the stethoscope to a patient, and the resulting signal could be connected up to a whole group of other units used by other people. That way they could discuss what it meant with confidence that they'd all heard the same thing. Or, the output could be recorded and played back later.
Your father may have good hearing now. But all human loos some hearing by the year, even your father who is a doctorMy father is a doctor and when I talked about my project with him, he said he dont have any problem with his ordinary stethoscope.
Till he hears something with the electronic stethoscope that he doesn't hear with his trusty ol' stethoscope.He thinks this idea maybe useful for someone who educating in medicine and cant diagnose well and an experienced doctor dont need sth like this.
The self confident doctor defenceTill he hears something with the electronic stethoscope that he doesn't hear with his trusty ol' stethoscope.
