electronic pocket chess, buttons not working, help
ninjaman
Joined May 18, 2013
341
hello,
i have a kasparov electronic pocket chess games with a coach function.
i bought it second hand and want to keep it as most of it works except two buttons.
i took the thing apart and found that there is a sort of mesh made of plastic. when you press the rubber button it presses the top mesh against the bottom and makes a circuit. i noticed that the trace from the two buttons to the chip is damaged. it is a silver colour, not sure what it is exactly. i tried putting some tin foil on it but that doesnt work. is there some way to connect the trace without solder as the mesh is a thin plastic.
EDIT: i have fixed it so never mind, never underestimate a man armed with cellotape and tin foil. give me moldy orange peel, two nails and a nuclear bomb and ill kill rambo!!!
bertus
Joined Apr 5, 2008
23,041
It could also be that the carbon on the rubber pad is worn out.
This could have damaged the PCB tracks for the contacts.
Bertus
