Electronic Level Indicator using LM3914
RodneyB
Joined Apr 28, 2012
698
I am trying to make a Level indicator for a see saw. ( I have attached my drawing)
On the input I have put a 5 K Pot to act as a voltage divider. The Idea is as this is rotated on the see saw the voltage will adjust and the Corresponding LED will light up.
When I made it the voltage adjusted in a very little of the pot rotation. The LEDs Were erratic some flashing some not coming on and it never could stay on one LED.
I would like to get them to light in a sequence gradually.
I would really appreciate some assistance as I can see where I am going wrong.
RodneyB
Joined Apr 28, 2012
698
There are some things not OK in your schematic.
I made some comments in your drawing:
Did you read the datasheet?
LM3914.pdf
I have looked at the datasheet and several circuits on the Internet. I "think" I have adapted it to suit my requirements. The Input voltage is 12 Volts through the voltage divider (RV1 and R1) the minimum voltage is 6 Volts.
VR1 sets the upper limit whilst VR2 sets the lower limit.
Because I anticipate the see saw moving quite quickly I have removed 6 of the LED's.
I would like to know if this circuit is plausible.
I am concerned that because of the See saw movement of RV1 there should be a 100nF capacitor across pins 1 and 2 of VR1. Is there something more robust that I can use instead of a variable resistor.
I would also like to use 10Watt LEDs can the outputs of the LM3914 switch Opto isolators.
Many thanks
Rodney
Reloadron
Joined Jan 15, 2015
7,978
Using a voltage divider as the power supply really isn't a good idea. Reason being as the chip cycles the current will be constantly changing and bouncing around. Keep in mind that your circuit is in parallel with R1 and part of RV1. The divider out voltage will vary and bounce around. If you want a stable supply you can just use a regulator like a LM7809 for example off the 12 volt battery or any other low dropout type regulator if the battery voltage getting low is a concern. Anyway, I do not see the voltage divider configuration as a good idea.
Yes, the LM3914 outputs can drive opto isolators, mosfets, and other switching devices.
Depending on the slew rate of the input voltage with your design there will be "dead" spots while the unused outputs are running in dot mode.
Ron
bertus
Joined Apr 5, 2008
23,033
What voltage range do you want to show on the leds?
How much current do you want to have for each led?
The voltage can be adjusted with the voltage reference and the in-high and in-low connections.
The current for the led is about 10 times the current drawn from the reference voltage pin.
RodneyB
Joined Apr 28, 2012
698
Because of the see saw motion I thought this was the best choice. Of IC.....
If I used all 10 of the LED's. The practical application of the circuit would be very confusing.
The object of the lights on the see saw is to help teach balance.
I could use limit switches that switch in voltage regulators or relays. To switch on the LED's. At this stage I am not to sure. The LED's are 10 watt I was going to make solid state relays to switch them.
At this stage any advice on a circuit Will be most welcome
RodneyB
Joined Apr 28, 2012
698
The LEFt's are 10 watts each. I chose to use every second outlet to not confuse things in the practicle application. I did out line other ideas above
Thanks for the help thus far
bertus
Joined Apr 5, 2008
23,033
You do not need resistors for current limiting for the leds on the LM3914, as the current is determined by the 625 ohms resistor in my schematic.
