I have been running a basic homemade EFIE on one of my cars similar to this:
The narrow band O2 sensor on this car is a single wire Zirconia sensor that generates a 0 -1v dc signal to the ECU.
I no longer want the EFIE controller to be powered by a disposable battery. From what I read when originally making the EFIE controller the power source has to be completely isolated from the cars 12V electrical system. I do know zirconia oxygen sensors are easily shorted by any positive current feedback.
I have a few different ideas about using a rechargeable power source and either a solar panel or battery charger and 2 Double Pole Double Throw relay to control connections between charger to AA battery and AA battery to EFIE controller.
Positive :Battery charger ------ N.C. side of relay 1------ AA Battery ------ N.O. side of relay 1------ EFIE
Negative:Battery charger ------ N.C. side of relay 2------ AA Battery ------ N.O. side of relay 2------ EFIE
Relay coils energized by ignition switched 12v + signal.
With a solar power source I think only the Positive current side would need to be wired through a relay. But I would rather not have to install a small solar panel in the car.
Can double pole double throw relays fail with both throws active?
Is their a current drain from a smart charger when it isn't charging a battery? If so how much?
(Questions that just came to mind).
So I have looked at smart battery chargers and making your own, types, sizes and outputs of rechargeable batteries... I have read many DIY write ups about all kinds of charging, solar, custom electronics, voltage isolation, signal isolation... but haven't been inspired by any alternative ideas. Most of what I find is not relevant to my specific application.
The world of electronics is so vast. Normally if I am looking for a solution or direction I find a similar example online, learn the components function, and how everything works and go from there. I am having a hard time finding a starting point that doesn't involve a AA battery. And all I can think to do is replace the disposable battery with a rechargeable battery and set it up to autocharge. I don't think this is the most durable or reliable solution and I don't feel it's fail safe for the Oxygen sensor, meaning it could fail and damage the O2 sensor.
I decided to ask the experts for a better way.
This is one of many hundreds of things I am doing on the car and seems like one of the simplest of those things but is proving to be most challenging.
The following has nothing to do with the above question but is about what the EFIE ties into and some of the other things on this car.
It all started when I purchased an expensive used Water / Alcohol injection system for one of my other cars, I decided I was going to make my own water / alcohol system for this car out of parts I had lying around.
I researched every popular system on the market, I found DIY set-up of all kinds and came up with my own system.
Alcohol, methanol, methyl hydrate require specific materials that can withstand them. The electric pump is the most expensive component of the available systems and the most prone part to fail.
I found DIY's where people used pressurized air tanks to pressurize the liquid in the system, as tank pressure dropped so did liquid pressure.
Another who used boost pressure from the engine to pressurize his system but in order to inject one pressurized substance into an evenly pressurized environment requires an expensive misting nozzle and elaborate pluming.
I decided to use an electric air pump to pressurize my system. I had a small broken air compressor, some small lab tanks, a liquid pressure regulator, braided high pressure stainless hose, solenoid valve, fittings and misting nozzles. I purchased a small permanent mount 12V air compressor.
Air compressor----air tank----air pressure regulator----liquid tank----liquid pressure regulator----accumulator tank----Braided hose----solenoid valves----misting nozzles.
The solenoid valves are activated by pressure switches:
The air pump and relays are activated by a main toggle switch. Engine boost is controlled using a modified adjustable solenoid valve (stage 3), they are activated by a second toggle switch, because I don't want to reach for the dash under acceleration I carved a hardwood shift knob to install the toggle switch on, because of the shape of the shift knob I made a custom adjustable shift rod that puts the knob at the right position and allows the shifter travel to be adjusted:
I then added a hall sensor to the shift rod and a magnet to the assembly that holds it. To identify 1st gear and activate a second modified solenoid valve when desired.
The water / alcohol system has a tank level sensor and tank pressure switch. If tank level or pressure is low the Stage 3 solenoid valve and shift knob button become inactive.
Everything is controlled and powered by what I call a Central Processing Unit :
The wiring for diagram for the CPU:
