Electronic decision unit
electronics123
Joined Feb 22, 2020
47
a charity organises quizzes to raise funds. They require an electronic decision unit to indicate which of three quiz teams presses their buttons first. The unit should include light and sound.
I need help with designing the circuit and test procedures as well as calculation
I am not allowed to use programmable components
The organisation has required the use of at least four logic gates, one input subsystem to provide a digital signal for logic gates an output subsystem, funcitonal intergration and power only from batteries or low voltage power supply unit(maximum 12 volts)
CAN YOU HELP ME?
28,101
hi 123,
Welcome to AAC.
Is this a College or School assignment.?
Why is a programmable MCU not allowed.?
E
Why use an MCU of any type? These devices have been built even using the old style electromechanical relays. The logic is fairly simple. Gates and flipflops are all that is needed. If the sound does not need to be really loud, and the light does not need to be terribly bright, then the system could run on a single 9 volt battery, otherwise a set of 4 "D: cells could be the power source.
This does sounds a lot like a school exam in a digital logic course. But it might just be a homework assignment.
It can be done as simply as 3 J-K flipflops (CD4027) and a 3 input OR gate. The input circuit can simply be a 4049 hex inverter with some small capacitors and 220 ohm pull down resistors. When any FF is triggered it's Q_ feeds the or gate removing the "J" input, so that the next FFs can not toggle. I did omit the reset circuit and the announcers but they are simple.
WBahn
Joined Mar 31, 2012
33,088
CAN YOU HELP ME?
This is pretty clearly an assignment of some kind -- and a pretty common one.
Make your best attempt to get started and show that. We can then offer feedback and small suggestions on what to do differently or what to do next.
You might start with a detailed sequence of events that goes through one cycle of operation. That will help you identify actions that are necessary but only implied in your present description.
MaxHeadRoom
Joined Jul 18, 2013
30,776
I agree, too bad about the 'no MCU' a small 8pin footprint micro would do it a cinch.
Strange a charity org that requires it stipulates a design criteria?
I guess the charity is part of fiction in the H.W. question!
Max.
WBahn
Joined Mar 31, 2012
33,088
Max.
Those are the things that wave the big flags signalling it as an assignment of some kind. The whole charity organization thing is just fluff to give the illusion of it being a "real world" problem. The "no MCU" restriction is almost certainly because using an MCU would render the assignment useless for developing and/or evaluating the knowledge and skills being targeted.
jpanhalt
Joined Jan 18, 2008
11,087
I've known students who might charitably be called charity cases.
Still there are several approaches out there and the TS can either try to develop something de novo or do a "literature" search.
28,101
If I were teaching a course in the design of digital logic certainly there would not be any MCU devices allowed in any of the tests, because that is no way to gain any proficiency in logic design. If one wants to be a programmer then take programming classes, and don't call yourself an engineer if you are a program writer. The areas are not similar.
I already suggested that the TS can create the needed functions with a very simple arrangement of JK flipflops. An added advantage of that sort of implementation is that it needs no input debouncing. Or maybe it does? But it is an easy logic project no matter what.
MaxHeadRoom
Joined Jul 18, 2013
30,776
In spite of the OP's vague description, It has become apparent that a logic device based result was required due to it being apparently a Homework question in this case.
But outside of this, I still maintain in a real world a micro would be the better decision, you obviously exhibit a predilection for logic circuits over micro's, but having gone through the logic era and later embraced the microprocessor, I see the great advantages to cleaner designs and smaller footprints for many answers.
Max.
djsfantasi
Joined Apr 11, 2010
9,237
IIf one wants to be a programmer then take programming classes, and don't call yourself an engineer if you are a program writer. The areas are not similar.
Just curious as to what you see as dissimilar between an “engineer” and a software engineer. Admittedly, the latter includes programming but additionally includes many engineering skills.
Your statement cannot be argued with as is. A programmer is not an engineer. His title is programmer, and not software engineer. But I detect a further attitude and wanted to dissuade myself that it was there.
electronics123
Joined Feb 22, 2020
47
hi 123,
Welcome to AAC.
E
This is a college assignment
in the design specifications no programmable MCU is not allowed
i have tried my hardest to the do the assignment but i have not been paying attention in school
Could u please help me? I want to excel
electronics123
Joined Feb 22, 2020
47
I am neither, i am simply a student struggling with electronics subject
electronics123
Joined Feb 22, 2020
47
Max.
Yes, it is homework, I am a student who takes electronics as a subject however i have been struggling with my project so help would be appreciated
electronics123
Joined Feb 22, 2020
47
I did not call myself an engineer, I am student who is struggling with the subject electronics and i have tried to do the project already but i simply do not understand the subject
