Electronic Circuit Question.
JoeJester
Joined Apr 26, 2005
4,390
Is these calculation are right?
I asked
I would recommend you tell me what each meter should read.
You gave me the current through each resistor.
Review Kirchoff's Laws and apply the applicable law to this circuit. Then answer my question.
p.s. If this circuit were asked on a job interview, I would thank you for your answer and stop the interview, rejecting your application.
how to know or calculate this.
Which component is shorted?
@RRITESH KAKKAR
That you need even ask such a question tells me you haven't so much as thought about the question!:rolleyes: -- Look at the diagram? Apart from the battery, what component do all the indicators have in common?
Hint: The implied 5nΩ should be regarded as characteristic of the battery and/or the indicators -- Come to that - it could all be in the defective resistor given that the indicators are limited to four digit precision:D -- This is a no brainier -- I've got to wonder if you aren't having a bit of fun at our expense???;););)
Golly! -- These fora are addictive:eek::)
Best regards
HP:cool:
Yes, it was far better circuit to understand
yes the circuit is normal working..may be R4 open because there is no current following can be seen.
@RRITESH KAKKAR
Does that make sense? Ask yourself what AM4 would read if R4=∞Ω?:rolleyes: --- I assert that you know better... --- How's about you cool the comedy and settle down to serious study? -- Give positive attention a whirl - who knows? You might find that you prefer it;)
Hopefully
HP:)
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
Let Calculate the total equivalent Resistance.
1/Req=1/R1+1/R2+1/R3+1/R4
1/Req=1/1kohm+1/2kohm+1/3kohm+1/4kohm
1/Req=1kohm +0.5kohm+0.33kohm+0.25kohm
1/Req=1/2.08kohm
Req=480ohm
so, we know Vt=It*Req
Vt=12V
Req=480ohm
It=25mA
AM1=25mA (AM2+AM3+AM4+IR1)
AM2=25mA-IR1(current through R1)
AM2=25mA-(12/1000)=25mA-12mA=13mA
AM3=13mA-(12/2000)=13mA-6mA=7mA
AM4=7mA-(12/3000)=7mA-4mA=3mA
IR4=2mA
I think there is fault in R4...
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
Kirchhoff's first law The current entering any junction is equal to the current leaving that junction. i2 + i3 = i1 + i4
Kirchhoff's second law The sum of all the voltages around a loop is equal to zero.
v1 + v2 + v3 - v4 = 0
JoeJester
Joined Apr 26, 2005
4,390
IR4=2mA
How did you determine R4 had 2 mA through it? I'll assume it was a typo.
There are ONLY 4 ammeters in the circuit. All are reading 12 Amperes. I had asked what they were suppose to read.
The simplest way to complete that task was:
AM4 = IR4
AM3 = AM4 + IR3
AM2 = AM3 + IR2
AM1 = AM2 + IR1
Now you stated
Can you expand on the fault? How many ways can a resistor be faulty?
33,243
1/Req=1/2.08kohm
Req=480ohm
Vt=12V
Req=480ohm
It=25mA
IR4=2mA
What would each of the meters read if R1 was, say, 1 Ω and all of the others were, say, 1 kΩ?
What would each of the meters read if R2 was, say, 1 Ω and all of the others were, say, 1 kΩ?
What would each of the meters read if R3 was, say, 1 Ω and all of the others were, say, 1 kΩ?
What would each of the meters read if R4 was, say, 1 Ω and all of the others were, say, 1 kΩ?
Which, if any, of these results are somewhat similar to what the meters are showing in the problem?
Could you please post links to threads where he demonstrates these capabilities?
He demonstrated skill at manipulating vectors (Ca post 700+ on his thread in the math forum) once he understood the question:) -- Moreover, he responded correctly to pool exercises in regards to phase shift attendant to impedances comprised of various reactance-resistance ratios/orientations (IIRC on a thread in the 'general chat' forum) the fora's 'search' feature may help...
FWIW: The intent of my challenges to his sincerity is less that of accusation than an attempt to 'rudely' acquaint him with the fact that he is in possession of the requisite skills - and, hence, quite capable of performing the exercises... While I sympathize with the desire to remain within one's personal 'comfort zone' -- I likewise recognize the fact that education (indeed, 'growth' in general) and 'comfort' are, not uncommonly, in diametric opposition... Point being: My intent is that of encouragement not harassment!:cool::cool::cool: --- Once again, I am not and never have been professionally employed as in instructor - neither do I claim proficiency or expertise at said 'calling' -- That said - it has been my observation that the distinction between "special" and "gifted" is frequently down to discipline (CIP concentration) and 'daring' alone -- whether 'innate' or 'acquired' -- The result is the same!!!:):):)
Many thanks for your concern
HP:)
