Electronic Circuit Equations
Claudinho18
Joined Jan 14, 2017
6
Hi.
I want to write the most efficient method's equations.
Can you help me, please?
I heared that this method is Cyclic Currents Methods( i don't know if it's the name in English).
Thanks in advice.
WBahn
Joined Mar 31, 2012
33,324
I think the method you are referring to is Mesh Current Analysis.
That is certainly one way to solve the problem and, in this case, a very reasonable approach.
How many mesh equations will there be?
Are any of them solvable by inspection? If so, which ones? What is left?
RBR1317
Joined Nov 13, 2010
715
Since this problem is complex impedance analysis in the steady-state frequency domain, you must have already studied node & mesh analysis for resistors with DC sources. If this problem were posed with resistance instead of impedance, consider how the node or mesh analysis would be structured. Would it be any different for complex impedance? (Other than simple arithmetic vs complex arithmetic.) Note that for the resistive case there is only one mesh current that is unknown, and there is a single super-node so that only one node voltage is unknown. Can you get more efficient than a single equation?
