Electromagnetic Pendulum (pulse movement)
aboosidhu
Joined May 25, 2018
5
I would like to make a cost effective (without using large circuit and micro controller and all)electromagnetic pendulum for my wooden clock(so the second wheel will move according to pendulum swings). So i found a simple tutorial from this link (http://www.trainelectronics.com/Pendulum/article.htm). But unfortunately it's not swinging properly pulse wise. Can anyone figure out my problem like am I missing any components or do i need to increase battery power or coil turn something like that? Working solutions will get appreciated.
Note: I'm a beginner to electronics. Here is my circuit details.
  • Battery - Duracell-2 (1.5 V)
  • Components used - As said in tutorial (You can see the circuit below)
  • Coil - 500 turn (28 gauge)
  • Input voltage - 3V output voltage- 0.8 V (observed in multimeter)
  • Round neodymium magnet
Observed Output
The LED glows only when coil not connected to the circuit.
Expected Output
1. Swinging pendulum pulse wise
2. Blinking LED when magnet cross coil
Danko
Joined Nov 22, 2017
2,241
You can use more efficient and working from 1.5V battery circuit:
Edit: Voltage source V2 used for simulation only.
aboosidhu
Joined May 25, 2018
5
Thanks for your valuable replay i have,
Few faqs
1.can i use 2N3904 transistor instead of 07?
2.10 mh L1 means how much turn it will be and gauge(my existing coil is 28 gauge ,500 turn)?
3. What R3 is about can i use 330 or 100 instead?
4.Can you predict the battery life with this circuit if i use continuesly?
Danko
Joined Nov 22, 2017
2,241
1. Yes, you can use 2N3904 transistor instead of 2N2907.
2. Try circuit with existing coil, then, if it will not work, we will talk about it.
3. You can use 100 or 330 Ohm resistor instead 510 Ohm (R3).
4. About battery life see table below.
LED D1 should be red.
Danko
Joined Nov 22, 2017
2,241
