Hi All ,
I need professional advice on a problem I am trying to solve . I am trying to sense electromagnetic field created by an iron-core coil from a distance of 12-feet. The Transmitter coil is 6-inches in length , #30 AWG wire is winded on it up the thickness of about 0.5 inches ( I don’t remember the number of turns ), its total impedance is 240ohms. See pic attached . I have a derive circuit in which a 555 is generating 25Hz of square wave its output is amplified by a LM1875 which is supplied +/- 25V to output amplified signal . The signal is fed into the winding and the other end is just grounded .
My Receive coil is a small with total impedance of 2.4Kohm because #44 AWG wire in winded on it , this coil is air core .
When I do testing I just connect both ends of Rx coil to the scope , I get very strong signals when Rx coil is line with either end of Tx coil because iron core amplifies the Magnetic field on both ends of Tx coil . I did some FEMM simulation and it shows that magnetic field should extend outwards beyond 14-feet . But I don’t see any signal or the FFT function of the scope doesn’t show any spike at 25Hz beyond 1-feet , although when Rx coil is inline with the end of TX coil I do see signal embedded in the noise . But my requirement is that Rx coil should detect 25Hz when place 12-feet away in length-wise parallel to the Tx coil .
Thanks in advance for all the valuable comments and replies .
