Electromagnet Power Supply Connector Getting Hot
Linky132
Joined Jul 6, 2019
10
I'm creating an electromagnet for a project I'm working on. My problem is, if I connect the two ends of the coil to the positive and negative terminals of the power supply for more than 2-3 seconds, the power supply connector literally gets smoaking hot.
Parts:
For the core, I'm using an iron core that I salvaged from a weather station. Dimensions: 50.0mm x 2.0mm x 7.0mm
For the wire, I'm using this
For the power supply, I'm using this
If you need any more information about this project, please feel free to ask.
I appreciate all responses.
Kind regards,
Linky132.
AlbertHall
Joined Jun 4, 2014
12,652
Your coil is drawing too much current - it doesn't have enough turns for use with that battery.
Can you measure the resistance of the coil?
Linky132
Joined Jul 6, 2019
10
Thank you for your very quick response. Is it possible to calculate the resistance of the wire without an ohmmeter/multimeter?
AlbertHall
Joined Jun 4, 2014
12,652
What is the length of each turn of wire (L in metres)?
30AWG copper wire is 0.339 Ω/m
The resistance of the finished coil will be R = 103 x L x 0.339 Ω
The current at 9V will be 9 / R.
Linky132
Joined Jul 6, 2019
10
Ok, so the resistance is 0.314
And the current that it's drawing is 28.66... amps? That doesn't make sense, does it?
AlbertHall
Joined Jun 4, 2014
12,652
It won't actually be drawing that much current because the batteries can't do it but it will be drawing a LOT of current - essentially you are short-circuiting the batteries.
How powerful does this magnet need to be?
If we say that a sensible maximum, short term current for an AA battery is 1A and you are using 6 of them in series then you need around 2700 turns of that wire on that former.
Linky132
Joined Jul 6, 2019
10
Oh, that makes more sense.
To be honest, I don't really know yet. Right now I'm sort of just seeing if it's feasible
Wow, that's a lot of turns! Is there any other way to reduce the heat?
AlbertHall
Joined Jun 4, 2014
12,652
You could try it with just one AA. That might give you about 4A.
Incidentally, you can get an idea of the strength of the field by multiplying current and turns to give you ampere turns.
Linky132
Joined Jul 6, 2019
10
I have tried it with just one AA in the past. It could only pick up tiny screws and paperlips
Okay, I'll bear that in mind.
So there's no other way to reduce the heat or stop it from trying to draw so much current?
Consider your magnetic circuit. If you can bring both poles to the armature (whatever you are trying to attract) the same number of ampere-turns will give you more mechanical force than a single pole.
Also, since it is a DC magnet, you want a soft iron core. Any chance what you have is some kind of ferrite?
Linky132
Joined Jul 6, 2019
10
Sorry, I didn't see your reply.
Sorry, I don't really unsderstand that. Could you explain it again, please?
I'm not sure, to be honest. Is there any way to test if it is a ferrite?
