Electrolysis Power Supply.
UCNCLLMEAL
Joined Oct 22, 2017
I'm trying to construct a viable power supply for copper electrolysis. My thinking is that current is my focus, so I have the circuit built to restrict and maintain currents with voltage as the "don't much care" factor. I have a standard household plug coming in with the "hot" going through a switch and then splitting into 5 rectifiers using 1N4007 Diodes. Each rectifier then runs through a 330Ohm 50W wire-round resistor then to a cap-bank rated to 175V 4400uF. The + then goes to the source-bar in the copper sulfate solution and the - to the target and then back through to the rectifiers. It seems pretty straightforward but something is just not right. The two diodes that feed from AC to + blew up on one of the rectifiers after a couple minutes, the resistors were getting hot enough to melt the plastic they were mounted on and the caps were reading 10V DC when going through the solution, but charging to the expected 170 without the tank on. My desire is to have about 2A of smooth DC current at 170V without overheating components or blowing up the circuit. Right now my draw through AC is 1.6A +-.2A.powersupply 001.jpg
bertus
Joined Apr 5, 2008
22,917
UCNCLLMEAL
Joined Oct 22, 2017
Further experimentation:
I rewired the circuit to use 2 rectifiers, each with a lead-in resistor of 330Ohm to protect the rectifiers. I hooked up 2 resistors in line with the tank to get some measurements.
UCNCLLMEAL
Joined Oct 22, 2017
Where is the 120 Volts AC coming from?
If it is direct mains powered, we can not help you, as transformerless power supplies are not allowed on this site.
Bertus
Whoops, well, the concept is the same, whether I put a transformer on or not, so let's put one in there and still aim for the goals? Current is the important thing for me here!
UCNCLLMEAL
Joined Oct 22, 2017
See here for the User Agreement.
Have a look at the following links:
http://myweb.tiscali.co.uk/andyspatch/rust.htm
https://forum.allaboutcircuits.com/threads/electrolysis-rust-removal-valid-theory-or-bupkis.78691/
http://www.instructables.com/id/Electrolytic-Rust-Removal-aka-Magic/
Bertus
Take this thread down, I need to rethink it since I missed that bit about the power supplies and that will change EVERYTHING
