Electro motor speed control with tacho
qobouky
Joined Feb 8, 2021
I would like to ask you for help with wiring of motor with tacho from washing machine with speed controller from china.
Motor: MCA 52/64-148 / KT15
Speed regulator: https://www.aliexpress.com/item/32912766976.html
red and white are the capacitor auxiliary wires, and 2 blue wires are the speed control feedback wires, the green wire is the ground wire.
I am sure how to connect tacho but I am not sure how do a rest. I guess that I should interconnect violet and black on the motor and then blue and brown on the motor connect to red and while on controller.
Motor - Regulator
orange ?
brown ?
black ?
violet ?
blue ?
red blue
red blue
GND green
Thank you very much for any suggestion
LesJones
Joined Jan 8, 2017
4,544
I think that speed controller is designed to be used with an induction motor. The motor in your diagram is a series wound (Universal) type of motor which are very common in washing machines. This type of motor has very poor speed regulation without closed loop feedback. Without feedback and with a light load they can go so fast that they destroy themselves. There is an IC that is commonly used in washing machine speed controllers that would be a good basis for a speed controller for the motor you have. It is a TDA1085C. The data sheet for this IC gives a suggested circuit for it's use.
Les.
MaxHeadRoom
Joined Jul 18, 2013
30,818
Very rare to see a Universal motor in washing machines now, they go back to circa 1980-'90.
Mostly Fischer-Paykel out-runner type now.
Max.
qobouky
Joined Feb 8, 2021
Hi All,
I am not sure if I can trust but I saw pictures where this regulator is connected to motor looks like mine. Unfortunately without connection instruction :-(
qobouky
Joined Feb 8, 2021
Hi All,
So I followed my sense and made it working. Connection is as i described and motor run and it is possible to regulate. Of cource I cvannot test TACHO without implementation
Motor - Regulator
orange - ?
brown - red
black - connected to motor violet
violet - connected to motor black
blue - green
red - blue
red - blue
GND GND
This setup works
