I'm working on a charging circuit for a self-balancing unicycle I'm building and had a few questions about power MOSFETs (specifically, I'm thinking of using the FQP27P06 - 60v, 27A max).
Questions:
Here's a preliminary design for the charging circuit:
The 3mm terminals are where 22v LiPo batteries will be attached.
Thanks!
Questions:
- Are there any consequences of leaving a MOSFET "on" for long periods of time (~2 hours)?
- Can you run current "backwards" through a MOSFET (i.e. drain to source when charging the batteries)?
Thanks!
