MisterBill2
- Joined Jan 23, 2018
- 28,593
Going back to post #1, it appears that the intention is to switch off the power if either battery pack approaches some lower charge level. OR is there some other purpose in mind??
I an guessing that normal operation is not to simply apply 144 volts to the drive motor. I have raced that way at one rental track,, max power at all times..But that is not recommended most of the time.
So I am guessing that there is some sort of controller between the battery string and the motors. THAT would be the point to get the low-charge shutdown control input. Avoid the contactor drain, it does nothing to move you down the track faster.
