electric field intensity question
TheSpArK505
Joined Sep 25, 2013
126
hi everyone
I'm having a problem with a small part of integrating a line of charges
the question is how did dp became d^2(p)
question is attached!
33,130
hi everyone
I don't see d²(p) in there.
I do see d(p²), which is NOT the same thing?
What's d(p²)? Does that look like anything familiar?
I also notice that z went to h. Why? I suspect I know, but without having the problem available it's impossible to be sure.
t_n_k
Joined Mar 6, 2009
5,455
Also shouldn't the first integral in the second line read...
\(\frac{ h \rho_s}{4\epsilon_o}\int^{a}_{\rho=0}\(\rho^2 + h^2\)^{-\frac {3}{2}}d\(\rho^2\)\)
The index negative sign is missing in the original equations..
MrAl
Joined Jun 17, 2014
13,788
I would have liked to at least follow this thread, but unfortunately the original document in post #1 is in a strange .doc format which WordPad doesnt read. What kind of format is this and any way to convert this into a more common file format?
33,130
Thanks much for posting.
Do you know what kind of file format that was?
Microsoft Word. It opened just fine on my machine. The equations appear to use MS Equation, which used to be an optional component but that I think is now part of the basic install.
MrAl
Joined Jun 17, 2014
13,788
Oh i see, thanks for that info. I wonder why it did not open then, you mean with Wordpad ? That's the program i have.
Back to the integral...
It seems that the easiest way to solve that integral is to use the technique of integration by u substitution.
In this case u could be equal to p^2+h^2, and then we just have to integrate a typical power of a variable, u:
integrate 1/u^(3/2) du
and since u is as above then du is simply 2*p dp, so the entire integral becomes:
(1/2)*integrate 1/(u^(3/2)) du
and then use the definition of u to solve for the new integration limits.
This looks like the electric field on axis of a thickish ring ?
33,130
Word and Wordpad are two different programs. Wordpad is (or at least started out life as) a hybrid of Word and Notepad, hence the name. Word is a full-featured document editor, while Wordpad is a small subset of it. Originally Wordpad only worked with ASCII text files and, perhaps, RichText, but now it works with quite a bit more.
MrAl
Joined Jun 17, 2014
13,788
Hi again,
Thanks to both of you, very interesting. I wonder why they went to an entirely different format.
Do you remember the old Win 3.1 app called, "Write" ?
I used to like that one a lot because it allowed true subscripts, but they stopped support on that, after i made quite a few documents with subscripts.
This is one thing that really bugs me about Microsoft, the way they handle changes in new versions of Windows. They even dont like the original Help file format anymore so the handler for that is now a separate download for Win 7. They say they feel it is not worthy of the new system.
One quick question left, is libreoffice similar to 'open office' or soemthiing like that? I think i used to have that a long time ago before i changed hard drives (several times over the years ha ha). Thanks much.
Back to the integration again...
Another thing that looks suspicious is the order of the variables in the numerator of the very first integral. The integration variables seem to be written in reverse order. That makes me suspicious of the whole text, as to whether or not any of it is riddled with typos.
33,130
There are definitely some typos as well as some things that are taken for granted. The order of the differentials doesn't matter in this case because the integrals specify what the variable of integration is for each one. Normally, this is not the case and so the order of the differentials has to supply the cues to know which integration limits go with which differential. Still, it's sloppy to not keep them consistent.
MrAl
Joined Jun 17, 2014
13,788
Hi Joe and WBahn,
Joe:
Thanks for the link. I downloaded it and installed so now i have the program that can read the documents again. Now i just have to remember that i have it :)
I had used it in the past but didnt have much use for it as most people were posting graphics or just regular pdf's.
I also see that there may be a slight conversion issue, because the graphics seem 'cut off' at the top, unless that was the way they were made in the first place. I see those graphics are not 'formula' strings, but are actual graphics, probably created in another application and then copy and pasted into the Open Office app. I tried the 'formula' thing and it seems to make perfect math text and symbols.
WBahn:
Yes, that's what seemed strange, that the order was mixed up, even though we all know how it should be. When i see something like that i check the rest more carefully.
At MIT I've seen other notations by noted physicists that swap the 'differential' and the 'body', for example:
We normally write (with the symbol for integration rather than the word 'Integral'):
Integral 2*x^3 dx
but they might write this as:
Integral dx 2*x^3
(also with the symbol for integration).
33,130
The problem I would have with the notation
\int dx 2x^3
Is that identifying the integrand becomes problematic and ambiguous. For instance, it would not be hard to construct a problem for which the solution worked out to be
\( \int 2 dx \) \(x^3 \)
Which they would then write as
\( \int dx 2 \) \(x^3 \)
and since they would probably leave off the parens, might easily write it as
\int dx 2x^3
A more likely case would be something like
\int \( 2x^2 + 3 \) dx
which they might write as
\int dx 2x^2 + 3
But now we don't know if the 3 is part of the integrand or not.
If they use a rule that the integration operator is applied to the next factor, then the ambiguity goes away because they would need to write it as
\int dx \( 2x^2 + 3 \)
But the question is -- would they.
We see all the time where people write
\int 2x^2 + 3 dx
which would properly parse as
\( \int 2x^2 \) + \( 3 dx \)
So it can be argued either way. Using the integral as a single unary prefix operator may make it more likely that people will properly delimit the integrand (since they have no choice) whereas using the integral sign and the differential as the delimiters for the integral make it more likely that you can figure out what was intended even with the write is sloppy with properly delimiting the integrand.
I prefer to use the integral and differential to delimit the integrand AND to properly integrate it one its own, too. But then, as a pilot, I believe in backup systems.
